Question about Pinnacle Dazzle DVC 90 (210100371) Video Capture
VHS Recording HI, are there any simple instructions for recording from an anologue VHS player through my Dazzle 90 into my PC? Do I need extra software? according to the box it came in it should be able to do it. The only instructions I can find are in the help section, But I can.t seem to get my head around it.
  • steve59 Nov 19, 2007
    Yes it did come with the software but I can't seem to get anything into the pc. It appears as if it is copying it but there is nothing saved. Are there any simple step by step instructions that you normaly get in an operational manual?
  • 279 Answers
It sounds like you have all the cables connected correctly, so I will assume that's true. If not, let me know.
For recording, I suggest using Windows Movie Maker. It's simple, and has everything you need. And, it comes with Windows. To find it, go to Start -> Search and type in Windows Movie Maker. You may want to create a shortcut for it, but you can just run it from the search window as well.
  • Open Windows Movie Maker
  • If the "Capture Video" menu isn't showing, click the down arrow beside it. It should already show though.
  • Click capture from Video device
  • Click Dazzle DVC 90. In "video input source", drag down to composite, assuming you're using a composite cable (ie, the red/yellow/white cables).
  • Call your footage whatever you want and save it to whereever you want.
  • Leave the next feild as it is, you want the best quality.
  • You'll then be ready to capture whenever you want. Just hit play on your VCR and the Start Capture button.
  • When you're finished and done recording, hit stop record, then hit finish.
  • Make sure "Create Clips when Wizard Finishes" is checked off too.
Let me know if that works for you.
Posted on Dec 18, 2007
  • 98 Answers
If it came with the Pinnacle software (Pinnacle Studio), that's what you have to use to move your movies from VHS to your PC.
Posted on Nov 19, 2007
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I dont have picture for recording
Welcome to Fixyah,
If yo can't see any picture please check your video cable connection.
>checked if the video cable is properly connected from dazzle to your camcorder.
>if you connect you camcorder,vhs,VCR using S-video then go ahead and click on option on step number 1 click on video input and then click on S-Video click also VHS input and then click okay.
>If RCA the same thing click on option then video input and then select Composite.
>Turn your camcorder,VHS,VCR on and then hit played button.
>checked your preview screen if the video image is now showing, If showing then start recording.
Mar 11, 2010 | Pinnacle Dazzle DVD Recorder
Trying to copy home videos onto dvd thru dazzle product connected between vhs player and my computer. Can witness video on computer monitor while recording and says copy is complete. But when I check dvd...
Open again your Intant DVD Recorder and then after that do the advance mode. Next on step number 1 click the full down arrowed and then choose your dazzle device. On step number 2 click on the full down arrow and choose your DVD writer. Make sure that you already inserted your DVD blank disc then hit prepared button message comes out just click okay.
Nov 17, 2009 | Pinnacle Dazzle DVD Recorder
LG RC389H. Can't record vhs to dvd
Put both your vhs and blank dvd into the player.
Go into VHS mode and press "Home" menu button.
Scroll across to "Easy Menu" and select "Dubbing".
Make sure you are at the place on your VHS where you want to record from and select the "Dubbing" button.
Press the Stop button to finish transfering.
When it has done recording file information, press eject once and select to finalize the disc.
And that's it!
Sep 18, 2009 | Televison & Video
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
Dvd recording using a pc
The product you need is called the Pinaccle Dazzle - it is basically a red/white/yellow composite to USB connector - it also comes with software for capturing your videos in DVD format on your computer (or you can record directly to a DVD disc inserted in yuor computer). I purchased mine at Best Buy, but it is available in a lot of places. It works great, and I have been busily converting those old VHS's to my PC, and then from PC to DVD.
-Tha Mp3 Doctor
Mar 26, 2009 | Philips DVD740VR DVD Player/VCR
VCR Recording
I go into dazzle premimun and there are no capture options.
Nov 09, 2007 | Pinnacle Dazzle DVC 90 (210100371) Video...
Pinnacle Dazzle DVC 90 (210100371) Video Capture Logo
246 people viewed this question
Top Pinnacle Televison & Video Experts
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
