Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Ice Maker won't produce ice through the door
I have a 3 yr old GE Arctica Profile model PSS26SGRE SS. The ice maker produces ice, but when I try to get ice through the door I most frequently have to either open the door to get it from the ice bucket itsself, or I have to get water first and quickly change to ice in order to get ice through the door. I've noticed that the light that comes on when you press for ice or water through the door, comes on brightly for water but either shuts off or is dim when requesting ice. I've noticed that frequently when I request ice, it sounds as though the freezer fan stops and starts again when I release the tab. Finally, it seems that if I'm able to request ice when the light is on brightly, I get ice. I'm sure it's a wiring problem, but Idon't want to have to pay for a tech to come out & I'm sure it's something I can adjust myself. Any thoughts?
  • GE Master
  • 1,606 Answers
You either have a bad interface board ( touch board ) or a bad main control board . You would have to go into the test procedure from the touch board to determine which is bad . The more I think about it though , I tend to lean towards the main control board . Once you get into the test mode , 0 and 4 would test communication between the 2 boards .
Posted on Jul 19, 2009
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispenses from frig but ice maker is not producing any ice. We've adjusted the temp up and down and it isn't doing any good. Any suggestions on what else to check?
Before you adjusted the temps, were you having cooling issues? If you were, those cooling issues would need to be resolved in order for your ice maker to function properly.
If you had no cooling issues, the first thing i always ask is when did you last change your water filter, assuming you have one. If you dont have one or it was changed recently, then do the following. Turn the ice maker off for at least one hour, then watch to see if it begins to cycle, the angled row of teeth will rotate. Some models will not operate if the door is open, so close the door light switch while you observe the ice maker. If the ice maker cycles, but gets no water, the ice maker solenoid valve will need to be replaced. If the valve needs to be replaced, you may sometimes find the fill tube that directs water into the ice maker is frozen with ice, this will have to be cleared manually for proper function. If the ice maker does not cycle when you turn it on, you have a bad ice maker or there is a wiring problem with your ice maker system.
Oct 01, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile arctica side by side- ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 23, 2010 | GE Profile Arctica Stainless Steel Top...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Dec 14, 2008 | GE Profile Arctica Stainless Steel Top...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Oct 10, 2008 | GE Refrigerators
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
354 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
