Question about Dishwashers
When I start my dishwasher water wont go into the dishwasher.
  • 6,784 Answers
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jul 18, 2009
My dishwasher keeps flashing i30 and wont start what shall i do
In your case occurred intervention of anti-flooding system.
Displayed Error is "i30"
The cycle is interrupted and the drain pump switches on.
Could be:
Water leakage from the tub - sump and various
connections (pump, upper spray arm duct etc.);
floating sensor blocked mechanically; microswitch
faulty; fill solenoid blocked mechanically; circuit
board faulty (solenoid triac short-circuited); wiring
faulty.
First, try to tilt dishwasher and see if leaking water from its bottom.
This is most commonly occurs.
Dado
Jan 20, 2014 | Electrolux Genuine ZANUSSI ZDF511...
We have a dishwasher that has water in the bottom ( water wont drain) and although the lights are on the cycle will not start.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 25, 2011 | Dishwashers
Wont start or take in water
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 03, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Beko dishwasher wont start it comes on wont fill up
hi there...have you checked the water supply to the dishwasher.......sounds either no water to the appliance or a faulty water inlet valve to the appliance
regards Sir Galahad
May 15, 2009 | Beko 24 in. D3421F Free-standing...
Wont start wont let me change the cycle it flashes at 45degrees
poured a kettle of hot water down the drainage part tried 20 mins later and worked think it was a possible build up of grease
Oct 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
340 people viewed this question
Top Dishwashers Experts
Owen Barnes
