Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
The engine wont start i installed some new coils
It turns but it wont start,it has gas and power
Pull off the coil ignition cable at the distributor and check for spark coming out of coil when cranking engine over. Use a heavy rag or glove to hold the wire 1/4 inch from a metal ground. Should see a strong blue spark when cranking to verify ignition is good. If no spark, check for battery voltage to coil on the coil primary. If you have current to the coil, suspect a bad coil, ignition module, crank position sensor, or cam position sensor, or pcm. The coil, ignition module, and sensors can be tested before replacing.
Jan 29, 2013 | Cars & Trucks
Pu t in new coil and distrubtor cap and rotor put in new electronic module not firing wont start
No spark at the spark plug? It may be the pick-up coil inside the distributor. This is the sensor that tells the computer the engine's crank position.
If the ignition switch is good, you should have power at the coil's + terminal when key is on. You might check for that.
May 08, 2012 | 1989 Chevrolet Camaro
My zx9r (f2p model) wont start it has a new starter condenserand cdi unit it wont start from the starter switch, if i bypass the condenser the engine turns over but still wont spark.the switch is dry with...
if theres no spars check the fallowing
1. check connection between coil and plug
2. check to see if coil is working properly
3. replace coil if needed
Good Luck.
Mar 25, 2011 | kawasaki ZX-9R Motorcycles
JUST REBUILT ENGINE, PUT ELECTRONIC IGNITION AND NEW COIL IN WONT START SHOULD THE COIL BE GROUNDED TO SOMETHING? SHOULD NEG WIRE ON IGNITION BE WIRED TO COIL, OR FRAME?
Only the frame of the coil should be grounded. The wire coming out of the coil is the kill wire. If it gets grounded the engine stops or wont start. This wire usually goes to the ignition switch and another wire from the ignition goes to ground. You have to use an ohmeter to see which wire in the ignition is grounded when the tractor is off.
Jan 09, 2011 | John Deere 4010,4020 Tractor Basic...
Engine turns and turn but it wont start after new plugse install
make sure you install the ignition coil housing correctly also check the connector to the ignition module
Mar 16, 2010 | 2001 Saturn L-Series
2005 gmc safari wont start checked coil spark
how much fuel pressure you have when turn key on
Feb 04, 2010 | 2005 GMC Safari
Just installed new moter and it wont start how do
I'm not sure if you have 1 or more coil packs, but if you get a Chilton manual, it'll tell you how to check primary and secondary circuits on each of the coils. You can also take the coils out and take them to Autozone and they can check them for you. A quick and easy way would be to take the spark plug end of one spark plug wire off, hold the electrode with a pair of WELL INSULATED pliers,( Only touch the insulated handle, not the metal on the pliers) hold it about 1/4 inch from a good metal ground, then have someone try to turn the engine over. If you're getting spark, you'll definitely see the sparking from the electrode to the ground. FYI Only take one plug wire off at a time to prevent mixing them up and make sure you keep your hands and other body parts away from anything that could hurt you. There is also a control module that, if bad, can make it so the car won't start. This can also be checked at Autozone for free.
Jun 29, 2009 | 1999 Jeep Grand Cherokee
Saab 95 1998 - wont start
The most common problem is the Direct ignition cassette, followed by the crankshaft position sensor. I am assuming that it cranks, but won't start.
Dec 26, 2008 | 1999 Saab 9-5
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
49 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
