Question about Psi Garden
I need to find a replacement wheel for a Husky model 1750 PSI pressure washer. catalog shows a part number of RTRT83979. Home Depot can no longer get them and I have looked all over the internet.
I have already tried searching the internet for washer dealers and parts companies.
    New Friend:
  • 3 Answers
I would check eBay, also harbor fright had and assortment of replacement wheels that could work if your handy with tools.
Posted on Oct 20, 2016
  • 14,707 Answers
SOURCE:
Anybody know how to remove the wheels on a Husky 1750 power washer?
where does the link-mechanical gov. rod connect to the carburetor on the craftsman pressure washer number 919.762350.
Sep 28, 2013 | Dayton Wire Wheels Dayton Twin-Piston...
1750 husky power washer
Buy a washer kit for it at Home Depot.
Apr 28, 2013 | Cars & Trucks
Blockage in pump of huskey 2600psi
You may need to have the pump replaced. Most Husky pumps under 3000 psi don't have parts available. If you bought it within two years, the pump should still be under warranty. Check with Home Depot for service centers near you. They should be able to verify if it qualifies for a free replacement based on the serial number.
Feb 15, 2013 | Garden
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
May 06, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher 1750 psi electric pressure washer is making in/out loud noise when switch to On and idling not pressing washer trigger.
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | Karcher 1750 psi Electric Pressure Washer
Problem with pressure washer line seems to be cracked the line that has the gun and puts the water out has a crack how do I get a new one?
Lowe's and Home Depot keep a supply of hoses. Take the old one with you, and match it up. Or, you can take your make and model number and order one on-line.
Regards, --W/D--
Jul 14, 2009 | Karcher 1750 psi Electric Pressure Washer
Pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
May 30, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Garden Logo
681 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
