Question about Sharp Televison & Video
How do i select finalise on sharp dv-rw 250h remote control
I do not know how to select finalise on this controller
  • Sharp Master
  • 5,874 Answers
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Posted on Sep 20, 2016
SOURCE:
Have lost my remote control, I have no manual for the player & how do I pull up the setup for finalisation on the screen without my remote. The discs were recorded in this player
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Jun 16, 2016 | Televison & Video
Hi, I have a Sharp DV-RW360H which has been working fine. I have dubbed various VHS tapes to DVD and now need to finally the discs so they can play in other machines. However when I press the setup button...
Try one of the discs in another machine. You only need to finalise them if you want to ensure no more is put on them. To finalise a disc you need to use the write or burn functions, not the setup menu. Get the manual for this from the sharp website and read it.
Dec 15, 2013 | GoVideo DV2130 DVD Player/VCR
I need a Sharp GA867WJSA LCD TV Remote Control
To select a remote control, you have to know about the setup codes to Sharp Brand TVs. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Check these links, and find out which remote control have setup codes to Sharp Brand TVs, in code list, and buy that brand remote control according to availability.
Brand name of the remote control isn't a matter, but, it should have setup codes to Sharp Brand TVs.
Oct 23, 2013 | Sharp Televison & Video
How do I finalise a dvd?
1. Press SETUP
2. Select DISC
3. Select FINALIZE
4. Select YES
5. Finalizing is complete. This operation may take a while to be completed. If you need the manual to show pictures of the operation, send me an email to LBrown18062@hotmail.com and I will send it to you right away. Please put "Sharp DVRW340U" as the subject. Lawrence Brown
Jan 22, 2012 | Sharp DV-RW340U DVD Recorder/VCR
We need original remote control dv-nc70u, where can find it
If you are looking to buy a replacement for the remote online I would suggest going to this website http://www.sharpremotecontrols.com/dvd-dvdr-vcr/. They Have quite a selection of remotes on their website.
Also if you aren't able to find the correct remote and would just like to get a universal remote for any sharp TV you can buy it here http://www.amazon.com/Miracle-Remote-for-Sharp-TV/dp/B000B8PCQ8 .
May 18, 2011 | Televison & Video
How can I unlock Sharp DV-SL2200W
To unlock your DV-SL2200W player follow the below instruction.
1. Switch the player on without disc
2. Using the remote control press "HOME MENU"
3. Select "INITIAL SETTING"
4. Select "OPTION" on screen
5. Press "OSD" button
6. Press buttons, 3,5,7,0
7. The player will automatically shut down
8. Switch the player back on
Now you player will be Multi Region.
Sep 05, 2009 | Sharp DV-SL2200W Player
Need to program sharp tv, no codes, manual lost
here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
Jun 03, 2009 | One For All URC-4330 Remote Control
Invalid Disc after finalising
clean your lens and change the cd
May 19, 2009 | Sharp LiteOn CD-RW/DVD-ROM Burner
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
I want some feedback for DVD Camcorders.
My non-authoritive answers are: 1. Can the DVD-R be played on the Camcorder without finalisation? I'll write no. This is based on one comment by an user plus numerous experiments with DVD+R, DVD+R/W and such formats. 2. Does the DVD-RW / DVD-RAM need a finalisation ? Can the DVD-RW / DVD-RAM be played back on the camcorder/DVD Players/Computers without finalisation ? Based on my experiments with DVD recording and the 3 DVD players I have in the lab, the answers are yes and no in that respective order. 3. Can the DVD-RAM be played in the camcorder and output recorded in a standard VCR Casette ? The media played in the camcorder but placing the media in the VCR doesn't work since it's a phyical media issue. 4. Can the DVD-RAM/DVD-RW be played in the camcorder and the output captured in a computer and then burnt back on the DVD-RAM/DVD-RW or Computer CD/VCD ? Sure, but my method skips the play and re-capture. The files on the media are just placed into the DVD creation software and a new DVD is recorded.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Televison & Video Logo
87 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
