Have replace fuel filter and vacumn fuel pump. There is spark to the engine. I have also checked the fuel line for obstruction and nothing...any ideas on what to check next.
Take the spark plug out and crank the engine over for 30 seconds to blow out any gas that may be in there. get another or a new spark plug and put it in and try to start it. maybe check compression to see if the valves are working properly. if you have spark and fuel and compression it should.
take the spark plug out and crank the engine over for 30 seconds to blow out any gas that may be in there. get another or a new spark plug and put it in and try to start it. maybe check compression to see if the valves are working properly. if you have spark and fuel and compression it should start.
