Question about Kenmore 22422 Top Load Washer
How is the lid switch changed on the sears kenmore washer
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I changed the lid switch part # 8318084 and the washer still doesn't advanced
u may have a bad timer? the lid switch usually controls wheather
it agitates and spins? not the advancing? it will not go into agitate to wash if u have a bad water pressure switch, ( which regulates when to start washing according to the level
of water)
Aug 15, 2014 | Kenmore Sears Washing Machine Lid Switch...
Kenmore washer lid switch
Yes all washing machines have these to prevent some one from opening lid and inserting hand or anything else while machine is spinning , once lid opens machine seizes to operate .
Oct 02, 2013 | Kenmore Sears Washing Machine Lid Switch...
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 03, 2010 | Washing Machines
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
With my old washer I was able to open the lid and it continued agitating. My new one does not allow me to open the lid while it is agitating. Is there a locking mechanism?
Whirlpool / Kenmore washers use a "Lid Switch" as a safety device.
On older models the switch would stop the spin cycle when the lid is raised.
Newer models stop both the Agitate and Spin cycles.
If this is a Sears washer see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Oct 21, 2010 | Kenmore Washing Machines
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
How can i change top load door switch?
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your lid switch is jammed or broken.
Go to the section on the Sears site for the Top and Cabinet parts and you should see the Lid Switch.
See the following for how to release the console and remove the cabinet to gain access to the Lid Switch.
Feb 20, 2010 | Kenmore 22422 Top Load Washer
I HAVE A KENMORE WASHER MODEL 110.92284100 THAT
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92284100
Go to the section on the Sears site for the Top and Cabinet parts and you should see #11 Lid Switch.
See the following on how to gain access to the console and how to remove the cabinet
If you un-plug the washer and pop off the end caps, you should see a screw under each endcap.
Remove the screws and the console should tilt backward. Unplug the lid switch from the console.
Using a screwdriver, snap off the clips holding the cabinet on, tilt it forward and it should come.
You should have access to the lid switch with the cabinet off and the console tilted backward.
Oct 23, 2009 | Kenmore Washing Machines
How to replace the lid switch for a top load kenmore washing machine model 110.92480200 part#1170635?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92480200
Look at the top and cabinet section and you should see how the switch mounts.
A concern that I have is that the part number on the Sears site for your washer is
Switch, lid Number:3352630Substitution:285671which isn't the part number that you quote.
Oct 12, 2009 | Kenmore Washing Machines
Lid Open switch needs adjusting
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26924500
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Go to the section on the Sears site for the Top and Cabinet parts and you should see #9 Lid Switch.
See the section on the Control Panel and look at Item # 8. This is a clip that holds the control panel onto the cabinet.
If you un-plug the washer and slip a thin putty knife between the cabinet and control panel where the clip is, the clip should release allowing you to tilt the control panel back to gain access to the Lid Switch.
Oct 09, 2009 | Kenmore Washing Machines
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
