SOURCE: Jaguar X Type estate rear hatch glass pops open on start up
Hi the fault is usually the button for opening the rear glass, this can be changed easily if it is not sezed to the wiper spindle D
SOURCE: Jaguar XK8 Valet key not working correctly
I have seen this before, each time i have seen it i have to reprogram the valet key. This needs to be dont at the dealership, make sure you bring the master key otherwise they cant program the valet key.
SOURCE: My key won't open the trunk of my car. Jaguar XJ6
May not be the answer but something I just learned. I was handed the "key" to my aunt's XJ6 and she asked me to clean it up for her,,, but what I found was that the "key" she handed me was the VALET key and would not open the trunk. I had to go back and get the other key from her. The VALET key was green while the masters that open all are black.
SOURCE: my jaguar x-type 04, remote lock does not work,
I have a similar problem in my x type. Although if I press unlock button on the key first and then use the metalic key to unlock it dissables the alarm.
Also according to the manual if you unlock by the metalic key the car starts a beeping sound its I think 15-20 second timer within which you should put the key and start the ignition (don't need to start the engin) this will dissarm the alarm if not the alarm will go off in 15-20 second.
Hope this information is of any use, am trying to get hold of Jaguar dealers to fix this issue. If you come accross any solution please do let me know too
SOURCE: How can I reprogram my Jaguar X Type Key so I can unlock and lock my doors?
if your just programming the fob to the module and it has not been replaced and your just needing a manual reset,then follow the folowing procedure:
1 Insert key into ignition
2 Turn key to 'I"
3 Turn key "II" and back to 'I' quickly 4 times
4 Alarm system will chime once when key is back to 'I' for the
fourth time
5 Remove key from ignition
6 Press any button on each key fob and alarm system will chime
for each fob if it has been programmed correctly
7 Press unlock/lock/trunk etc to make sure everything works
Testimonial: "Thanks so much! I found out that my battery needed to be replaced ugh had to get it towed to Jaguar dealership.. cost me an arm and a leg! Thanks again!"
