I have an older model, I have it set on High cool. The other setting had the work Temperature.and the number 1-10 to get the coolest air do i set it at 1 or ten
    Champion:
  • 233 Answers
Usually the higher the number the longer the run time =the colder the temperature
Posted on Jul 20, 2009
Is 18 the lowest number on my Delonghi conditioner and the lower the number the coolest?
15 to 20 degrees air temperature difference is what an a.c. will do. 75 degrees return air should be 60 degrees in the supply. If your machine is in that range it is working fine and is cooling all it is ever going to cool. Hope this helps!!
Jun 25, 2017 | DeLonghi Heating & Cooling
I have a Whirlpool Model ACQ158XPO wall/window air conditioner. Motor comes on but it does not cool. Any suggestions?
Its really tough to troubleshoot window units without pulling the cover off. If I was standing there looking at it without tools in my hand I would first make sure the fan/cool switch was in the fan high cool mode and that the thermostat was turned all the way to the coolest setting. Beyond that it needs to go in for repair. Wish I could be more help. Good luck.
Oct 05, 2014 | Whirlpool ACQ158XP Wall/Window Air...
1994 Ford Taurus GL - Blows ambient temperature air when set on coolest setting, heat works normally. Refrigerant is full and no leaks in the line. Any ideas? Before I parked the vehicle last year, I...
If the refrigerant is ok the compressor should be coming on. If it isn't, check the AC fuse. Since it was not up to par when last used, it sounds like the refrigerant is low in charge though. If it is low enough, the compressor won't start.
Jun 05, 2011 | 1994 Ford Taurus
On the inside refrigerator temperature knob is 1 the coolest or warmest temperature?
most often the lowest number is the warmest setting, and the highest number is the coldest setting.
Dec 10, 2010 | Danby Designer DAR1102W Refrigerator
My climate control starts blowing hot air while a/c is on
Make sure you have fully charged AC sytem first, if so Im sorry to tell you this but this is a difficult deal.you may not be able to correct this without taking it to a repair shop with gm scan tool. Reason being the actuators for the hvac that most likely are malfunctioning from either them or another component being bad , require recalibration.The other reason would be the body control module related.It would have to be scanned for U codes which can effect the hvac control.Sorry but thats what I know.
Sep 06, 2009 | 2003 GMC Sierra 2500HD
Cannot set a/c to operate automatically
sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
May 23, 2009 | Sanyo Split System Air Conditioner
HEATER ISNT HEATING UP THE ROOM ENOUGH
It sounds like the space is too large for the BTU capacity output of the unit.
Did the unit ever heat the space?
Have you measured the temperature of the incoming air, vs the discharged air?
And finally, based on the Model number in the heading of this thread, this unit is cooling only, no heating (it's not a heat pump).
Jan 11, 2009 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
