Question about HP PSC 950 All-In-One InkJet Printer
I cannot get my cartridges to align. I keep getting a error message. It print black, but not in color
    President:
  • HP Master
  • 566 Answers
Have you already solved your problem? There are at least three posts about the same problem and about the PSC 950.
If you solved your problem, please comment, saying how you did it, so you can help others.
If you didn´t solve it, check this HP FAQ:
Solving Print Cartridge Alignment Problems
Note that it says (in the end) that you can bypass the alignment page and use the information from the last successful alignment in your printer, by pressing and hold the Enter button, and then press Setup .
I offered this same suggestion to another poster, who replied it didnn't solve his/her problem. It might work for you though. Please try and give some feedback (even if it is not positive).
Posted on Sep 03, 2009
SOURCE: Printer cartridge alignment
Hold "setup + options" at same time while turning off printer and back on while holding "setup + options"
Posted on Apr 04, 2007
  • 619 Answers
SOURCE: print head alignment failed
Open printer icon press right click appear nozzle check /print colors w/out spaces the head are clean/but there are spaces within the color head need toclean.
Posted on Jan 10, 2008
SOURCE: Printer won't print color only black and white
Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
Posted on May 24, 2008
SOURCE: align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Posted on Sep 13, 2008
Ajkill
  • 2035 Answers
SOURCE: error problems wi Dell 626 all in one printer
Try these steps if this did not resolve try to clear the memory of the printer
and try to print ..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Feb 03, 2009
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
I keep getting a cartridge error message. I have replace the ink cartridges but still have the error.
Are you using Dell Series 11 ink cartridges?
Open the printer with the power on and remove the Dell Series 11 black ink cartridge and make sure the tape is off the cartridge, then reseat the cartridge back in. Now do the same for the Dell Series 11 color cartridge. Now when you close the printer, it should print an alignment page. Any error messages?
Black = Black side(left side) Color = Color side(right side)
Photo = Black side(left side) Color = Color side(right side)
Dell Series 11 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 11 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It possible to get a Dell Series 11 Cartridge with a bad sensor. Take back to place of purchase for a replacement.
Rick
Jun 15, 2011 | Dell 948 All-In-One InkJet Printer
We keep getting left cartridge incorrect message?
Are you using Dell Series 5 ink cartridges?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jun 12, 2011 | Dell 946 All-In-One InkJet Printer
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
When I change the black ink cartridge, the alignment page and instruction page are printing out fine. When I place the alignment page on the glass as instructed and press 'ENTER', the printer gives a...
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Mar 20, 2009 | HP PSC 750 All-In-One InkJet Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align cartridges error
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
174 people viewed this question
Seeker5211
Seeker5211
