Question about Homelite Garden
How do you lock shaft rotation on a john deere s1400 trimmer. I am trying to replace the head with a PIVOTRIM
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: trimmer runs good but does not cut grass
I have had a similar problem with an edging attachment. The socket that fit onto the shaft was worn, and the shaft would just spin, creating a lot of heat right there, but very little movement, and it would completely stall when you tried to use it implement, even though the moter still ran just fine. The cure, I'm sorry to say, was to replace the implement.
Best regards, --W/D--
Posted on Aug 15, 2009
Testimonial: "Thank you... I will check how much is the replacement cost."
woobie dog
  • 1273 Answers
SOURCE: I need to know how to re-string my John Deere
Hello, W/D here.
I'm afraid that mental pictures are the best I can do, but bear with me; I'm good at it....We'll go over the spool parts, and the first time you wind tha spool, don't put any line on it....just read the directions while you hold the spool in your hands. Get a feel for what you are going to do. See how it will fit where it needs to go.....
All right......
Pull the spool out of the head.
Just look at it. You'll see that it is actually two spools.
Look at the divider between the spools. See the notch?
Look at the middle of the spools, or the core, where the line winds on the spool. See the small holes, one for each spool?
Flip the spools upside down. Look at the bottom. Note the notches in the rim of the bottom, and the arrows indicating the direction to wind the line. Look near the notches. There should be numbers next to the notches. This is the line size that fits your machine.
Take a brief look into the hole where the spool will attach to the head. We'll talk about that in a minute.
All right, let's do it. Remember, no line for the first walk thru. Take your line and snip the end at an angle, say about 45 degrees. Now take the pointed end and poke it about 1/8" into the small hole in the core of the inner spool (the spool closest to the bottom of the spool assembly). The purpose of placing the line in the hole is to anchor the line while you wrap (load) the spool. Start wrapping the line on the spool, going in the direction of the arrows. When you have that spool wrapped almost to the diameter of the rim, place the line in the bottom rim notch that is 180 degrees from the notch that is in between the spools. The line should fit into the notch snugly. You want about 6" of line to hang out past the notch and cut it so you have a 6" tail hanging out.
Now, fill the outer spool the same way. When you get it full, you'll pass that line into the notch in between the spools, and anchor it into the notch on the rim. Again, leave about a 6" tail, and cut it off.
Hard part's done. Get the spool close to the head, and thread the tails into the grommets on the machine head. Once both ends are in the grommets, straighten up the spool (align the notches holding the tails with the grommets) and push the spool into the head.
Almost there! When the spool is firmly set in the head, you'll feel a bit of a click, Grasp the tails, and tug on them enough to pull them out of the notches that were anchoring them to the rim.
Let's check our work. Push the spool in, simulating bumping the spool on the ground to advance the line. Once you have pushed it in, tug again on the tails. You should pull about an inch or so from each side, and then the line will stop.
Once you have that, you're done!
Now, about the hole in the bottom of the spool where it connects to the trimmer head....Sometimes, the line will be difficult to advance, so you should clean it out a bit from time-to-time. The trick that will help you is that, after cleaning it, put a little graphite dust in the hole. This lubricates the advancing mechanism without leaving an oily residue that will collect debris. Don't do it this time, maybe not next time, just some time. I probably do this maybe every eighth or tenth time I wind the spools or so. I buy the graphite usually at Lowe's or similar. It's used for locks, but you an also get it at Hobby Lobby where it's used for Cub Scout race cars (Pinewood Derby). Same stuff.
Sorry about no pictures. Turns out you didn't need them after all!
You've been a great student, and it's been a pleasure.
Posted on Aug 18, 2009
  • 16 Answers
SOURCE: Start Pull cord replacement on John Deere s1400
Take the 4 bolts/screws loose that hold the shaft onto the weed-eater body, You will see the clutch drum, you need a long T20 TORX driver to loosen the screw in the center of the drum shaft. The screw probably won't come all the way out, so just pull the drum off as you loosen it.
Next you will see 3 flat clutch discs.
You may need to remove the spark plug and stuff some starter rope in the combustion chamber to keep the shaft from turning.
Unscrew these one at a time with a pair of large slip joint pliers. Be careful not to bend them and note which way they face. They unscrew clockwise I believe.
Once you have these out of the way, continue taking apart the plastic housing to gain access to the starter rope assembly. There is a spring under the rope reel, so remove the screw holding the reel in place and carefully remove the rope reel and spring.
Replace the rope, put the reel back in place and make sure the sping egages the little tab. Then wind it a few turns until there is moderate tension on the spring.
Feed the rope through the body and tie it to the T-handle. Replace the hold down screw that keeps the rope reel in place.
Test the pull tension before reassembly. It should retract the rope fully without too much tension and should not be loose. Lubricate the rope reel where it rubs against the housing with some light grade oil or lithium grease.
If everything functions, put it back together in reverse order.
Remove the rope from the combustion chamber and make sure there is no debris in it. Install the spark plug. You should be ready to go.
Posted on Aug 21, 2009
How do you remove trimmer head from a John Deere model 260G Grass trimmer in order to replace with a Ugly Head
Block the arbor from rotating- should be somewhere you can shove in a small pointy object to lock it.
Then, looking from below, rotate the head CLOCKWISE to remove it. (Left-hand-threaded.)
And ... if all else fails, one can read the instructions. :')
Jun 15, 2016 | Garden
How to remove the pivotrim head from a grass trimmer
There are usually flats above the head to use a special flat wrench to hold it with.
Or take the engine off and hold the shaft very carefully not to scar it
Jun 04, 2014 | Rino Tuff Pivotrim String Trimmer Head for...
I have a new Pope Renegade 26cc Line Trimmer. Started it up but the cutting line bump feed would not operate. Removed the spool from the spring head and the line was tangled. I removed the tangled line...
Hi John, I have exactly the same problem. I can't go further than about 5 feet before I need new line. I can't help, but I thought you might like to know you are not the only one having problems with this trimmer!!
Sep 09, 2011 | Toro Garden
How do I remove the spoolhead so as to afix the pivotrim head
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
Enjoy! :-D
Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
I installed a new universal line head to my john deere c1200 trimmer. now it does not spin. it worked fine prior to the change. i disconnected the curved portion of the trimmer prior to attaching the new...
The shaft inside the tube is not properly installed either in the clutch near the engine or in the trimmer head itself. Take the head off and make sure the shaft is all the way in so that is is seated in the clutch. You may have to turn it with your fingers until you feel it go in. Next make sure the shaft and head line up. You will need to make sure they line up which you can see if you look at the shaft and head. i hope this helps./
May 15, 2011 | John Deere Garden
Trimmer won't start
The fuel line may not have a good seal to the fuel tank.
Jul 11, 2010 | Garden
John Deere S1400 won't start
I have the same problem. I replaced the primer bulb, and the fuel lines. Still no gas to the bulb; (It ran fine before I replaced the primer bulb)
Sep 24, 2009 | Garden
Trimmer runs good but does not cut grass
Aug 15, 2009 | Craftsman Convertible 25cc. Gas Line...
How do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
Jun 14, 2009 | Garden
Garden Logo
160 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
