Question about RCA Televison & Video
We have liquid trapped between the screens, how do we remove the front screen to get it out
    Novelist:
  • 85 Answers
If liquid, what did you spill?
There are two screen on a DLP. One is a Fresnel lens that focuses the light from a point source to parallel rays. It has circular ridges that are like short segments of a normal lens, just weighs a lot less. The circles get tighter together as you go to the edge. Then the outer plane has horizontal ridges that concentrate the light in the viewing area on eye level to increase the brightness. They face each other and should be close but not touching. Anything between them is a problem--liquid or not. You may find on AVS Forum for your model a description of disassembly for the screen--it is likely more tedious than difficult. Have a large work area. Do not scratch either lens and put it back the same way. There will be some trick in taking it apart. If the outer screen has been pushed to hard they may have stuck together, hope not or you may be buying the assembly. -Ken
Posted on Jul 19, 2009
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Tip
This worked for me. I was getting a F05 fault code. I found a sock, legos, money...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Oct 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bra stuck in lint trap housing on samsung front load dryer
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Jan 22, 2013 | Samsung WF337AA Front Load Washer
I had water drip from the ceiling onto the front face/screen. It appears water dripped down between the bottom bezel and screen. Now there is a 1"x2" dark spot at the bottom of the screen. It...
Hi Kevin this type of problem needs to be serviced. What you see is liquid trap in the LCD screen that might damage other parts of the LCD if you wont fix it. If its under warranty call the Mitsubishi support.
Feb 01, 2011 | Mitsubishi WD-65733 65" HDTV
I have a 55" toshiba
If you use a clean lint free cloth with a mild solution of washing up liquid, that will remove the greasy marks. Be sure to wring the cloth almost dry before use as we don't want liquid flowing down and into the electronics through the tiny gap between the screen and the front panel.
Hope that helps.
Nov 02, 2010 | Televison & Video
Residue inside LCD screen.
Hi there.
Here is an in depth guide on how to separate the layers from the screen, it's imperative that you take extra special care while you do this repair because if you damage the screen it can be costly!!!!
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Good luck
Jun 10, 2009 | Samsung R610-64G Laptop
Individual package of detergent fell into lint trap of Whirlpool
HI, You should remove it. Here is how Normal 0 UNPLUG the dryer! Remove the two screws under the lint screen and pop the top up by inserting a flat blade screw driver in the gap between the front panel and the top. Remove the rear panel of the dryer and locate the four 5/16" screws that hold the lint screen housing to the bulk head. Pull the lint screen housing away from the bulkhead and reach in to remove the item that fell.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 28, 2009 | Whirlpool LER5636P Electric Dryer
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
45" mitsubishi TV with gray/black "water stains" on screen
If the plastic screen has not been damaged by chemical properties in the liquids, the screen does not separate. Time will tell.
Apr 04, 2017 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
