I dont have volume icon in my task bar. sound r working. just icon iz not there when i ''select show icon in task bar it says that '' volume control programe not installed
  • 76 Answers
Are you using WinXP?
Is so open
SETTINGS
CONTROL PANEL
SOUND AND AUDIO DEVICE
First window opens make sure the checkbox is checked that says
"Place Volumn Icon in Taskbar"
Posted on Jul 18, 2009
I get picture on Viber laptop, but no sound. How do I get speakers to work and where can I find the speakers.
Check to see if you a speaker icon in the lower r/h side of the task-bar down by the clock.
If the icon is not there right click on a blank area of the task-bar and left click 'properties'
Left click 'customize'
Scroll down to 'Volume' and select 'Show icon and notifications "
Click 'OK'
Close the 2 properties pop-ups.
Right click on the speaker icon and select 'playback devices'
The 'sound' pop up will appear showing whatever you have connected ( speakers or headset etc)
Make sure the speakers are set as default if you have more than one sound device connected.
The speakers should have a green tick (check ) when they are ready to use
Right click on the speaker icon and select 'Open volume mixer"
Check that the volume slider is above 50% and the speakers are not muted (shown as a red no-entry sign on the speaker icons at the bottom of the sliders' If muted click on the slider speaker icon.
Right click on the speaker icon and select 'playback devices' Put the cursor on the blue graph to the right of the icon, right click and select 'test' All being well the computer speakers will respond.
Dec 03, 2016 | Cell Phones
My volume icon on the task bar has disappeared, how do I get it back
Open the TASK MANAGER, open the PROCESSES tab, highlight "explorer.exe", click on "end process", Open "file", "New Task", Type "explorer" without quotation marks. OR Control Panel, Sound, depending on your OS, You will find a box to show tray icon. If it is checked, uncheck, apply, then check, apply. The Task Manager will remove stored icons that fill the program, and restart the icons.
Nov 28, 2012 | Dell Inspiron 1501 Laptop
Wintheres no volume icon on my laptop
you need to enable the volume Icon to show it at the task bar to do it,click the start icon then choose control pannel select sound and audio devices check the "place audio icon at the task bar...good luck!
Sep 30, 2011 | Microsoft Windows XP Professional
Volume speaker icon not show
The volume speaker Icon wont show usually because you have no sound drivers installed. To confirm this,
1) Go to your control panel and double click on "Sounds and Audio devices"
2) The window that appears sholu show the device volume slider active - which means the driver works fine and is installed. If this is so, click on "place volume icon in task bar".
If not, you need to install the sound drivers for your device.
(Don't forget to rate my solution)
Dec 02, 2010 | Audio Players & Recorders
Is there a sound/volume lock key that may have been hit by mistake........audio and sound in my computer dont see any fault, but have almost no sound
I can help you with your 'almost no sound' computer problem.
The best thing to do when you are not sure what your pc is doing with its sound is to bring up your audio mixer. Do this by right clicking on the volume control icon by the clock on your task bar and selecting 'Open Volume Control', or go through the Control Panel if your taskbar has no volume icon visible.
When looking at your mixer, set Master Volume and Wave mixer bars to about 75%. Now return to whatever application you are using and check where its volume is set. Generally, everything should be set to 75% and then your external speaker volume should be set to a comfortable level.
I hope that helps.
Aug 30, 2010 | Acer NSK8458AN Keyboard
The master audio control is not shown in my toolbar..there is sound but i cant control it.. like i want to make it louder or softer or mute. what should i do?
Hello you can enable this option(showing volume control in task bar).This is how you enable it.You click on Start button and continue to the Control Panel item of the Start menu,then in the Control Panel window find Sounds, Speech, and Audio Devices section, click on it.Then click on Sounds and Audio Devices.In the Volume tab (top line of buttons) you will see a check-box"Place volume icon in the task bar" put a tick on it and click Apply.Now you are done and you should see the volume icon:)
Feb 03, 2010 | Compaq Presario 700 470024-192 Notebook
Unable to see the volume icon on the screen,so not able to adjust the volume
hmm you didn't specified what kinda operating system you use...but assuming that is XP ...I suggest to go to the control panel ...select sound and audio devices ..after you double click and open ...select the first option ( volume ) from the top choises...and see that you have two option to check ...one of them is " place an icon on the task bar " .....from here its easy ...it will place on the task bar ( system tray ) the speaker icon u was used to ....
Sep 03, 2009 | Computers & Internet
I have lost the volume control icon from the desktop toolbar and want to restore it
To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
May 21, 2009 | Dell Inspiron 1501 Notebook
I was given as a gift a acer aspire 3002CLi laptop and i must of muted the sound and i dont know where the volume control is please help.
hi, you want mute the sound ok, it's easy. After you enter the windows see the task bar it contains more icons and application .In the corner of the task bar you can see the clock or time display before that more icons there you see the sound icons it's like the speaker . Double click it the volume control comes select the first options volume bar and select the option mute all.if you could not get the icons from the task bar . then goto
  1. start menu
  2. control panel
  3. sound and volume controls
  4. select the sound control tab
here you can get the voume control tab . after all these process you cant get it please inform
Apr 28, 2008 | Computers & Internet
Loss of volume button
click on start then go to setting then control panel in control panel go to sound and audio devices i n that you will see volume tab in volume ther is option called place volume icon in the task bar just select taht and apply it it will show spk icon on your task bar but be sure that your sound card is properly installed. pls get me back if you need further assistence. bye
Sep 24, 2007 | HP Pavilion a815n (PS512AA) PC Desktop
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
