Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice shoot freezes up
My icemaker shoot keeps freezing up. The water flows ok and the ice is being made but does not come through. It is a GE side by side refrigerator. Model # PS123GPABS Serial number VF406971
  • GE Master
  • 1,606 Answers
If you use a lot of crushed ice , then it will freeze up . Also if it does not open completely or close completely , the plunger and solenoid for the dispensor flap could be rusted .
Posted on Jul 19, 2009
GE Side by side Refridgerator (Artica) model PSC25MSTA. Freezer and refer side not cold. Noticed coil under ice maker hot. Did a test on ice maker per GE web site instructions, Tested OK. Noticed cold...
No,what it appears to be isthe evaporator is freezing over and hindering air flow. The water under the ice maker is actually condensation because the ice maker is colder than the cabinet temp. The unit should have an automatic defrost so it appears it is cycleling through yhe defrost. Unless you call out a tech to set the defrost timer, all you can do is unplug it and defrost in its own. Was the door ajar for any period of time? not completely closed? That will also do it because of humidity. The moisture in the air will freeze. The refrigerator side cools from bleed over from the freezer.
Oct 10, 2009 | Refrigerators
My icemaker motor keeps freezing up. I can take
check your ice machine to be level, most are installed level, but then the installers tilt the machine back just a bit to assist in door closure, if your ice machine is even slightly out of level, it will over fill and clogg the motor the very first ice cycle
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice ,just flows water over the side of icemaker and freezes
Check and work Ice level shutoff switch back & forth sounds stuck open allowing to much water.
Jul 25, 2009 | GE Refrigerators
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker
Jul 16, 2008 | Refrigerators
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
333 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
