Question about Honeywell Programmable Thermostat Heater
The led numbers on the thermostat are blinking now after technician replaced low volage wiring. Did not blink before wire was replaced, do you know what would cause this?
    Champion:
  • 233 Answers
If the system is now operating correctly, there may be an issue with the batteries in the stat, if not he/she may have landed the wires on incorrect terminals
Posted on Jul 19, 2009
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
Panasonic tv plasma blinking red led
This is what it says on Panasonic's website:
"Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases."
You'll probably need to call a repair man to fix your TV.
Mar 05, 2011 | Panasonic TC-50PX24 50 in. Plasma TV
My central heating is on lockout and the burner is with red light
A sampling of various codes on a furnace
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your Goodman furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Dec 02, 2010 | Heating & Cooling
I have a goodman air handler that will not produce heat. The trouble light blinks once indicating no gas, gas valve, flame sensor. How do i know which it is?
if it lights and goes right back out its the flame sensor if it dont lite at all check all of your rollout and limit switchs ( they look like buttons) just jump them out with a jumper wire also you can jump out the gas valve to see if it works by putting a jumper wire ( small section of wire with alligator clips on both ends ) from the red terminal screw on the low volage side to the m1 terminal it will click open if it works , make sure the door switch is closed so you can have power while testing . do not try to leave furnace on with jumpers in it will burn your house down !!
Nov 09, 2010 | Goodman CKL36AR36 Air Conditioner
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
LED light blinking constantly
short in a/c wires on contactor is bad, disconnect wires at a/c and power up if no pop fuse it is the contactor. if still pops replace wire.
Apr 24, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Blower comes on but no heat
If there is a problem with the furnace, it will display a number of blinks on the circuit board. You will need to look thru a small window because if you take off the access door, it removes power from the furnace and erases the code. Once you count the number of blinks, now remove the access door and on the reverse side you should find a diagnostic error code chart to get you started looking in the right direction. If there are no blinks, it means that the thermostat is not sending a signal to the furnace to start (check the thermostat for proper operation and wiring).
I hope this helps.
Nov 09, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
133 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
