Question about Refrigerators
My maytag refrigerator model mtg2656ge is frosting up in the back of the freezer. I thinkg the flow of cold air is being impared by the frost. three wees ago I defrosted the freezer and it seemed to correct the problem. Now it is back.
  • suppacpa Jul 22, 2009
    how do I install a defroster timer in a maytag fridge?
  • suppacpa Jul 26, 2009
    yes it worked
    President:
  • 1,776 Answers
You did the right thing in defrosting the refrigerator, since you identified that it seemed to help the problem. Good diagnostic work!! Because it seemed to correct the problem when you defrosted it, but now the problem has returned, it would indicate that there is a problem with one of the three components in the self-defrost system:
1. The defrost timer.
2. The defrost thermostat (also called the bi-metal switch)
3. The defrost heater.
Just my opinion, (and I have been wrong before), that the problem is likely in the defrost thermostat. It is always located near or attached to the evaporator. The problem is that this item cannot be field tested and must be replaced if suspected of causing the problem, so you are taking a chance.
Anyway, I sure hope this helped you and that you find a resolution to your problem. Best wishes.
Posted on Jul 23, 2009
  • Bruce Canfield
    Bruce Canfield Jul 23, 2009
    The defrost timer is usually located either in the control panel, behind the toe kick panel, or on the back wall of the appliance. It will be white, black, or silver and black. It is attached with a couple of screws and typically has four wires attached. Simply note how the wires are attached, remove old timer, install new timer, and plug in the wires.
    President:
  • Refrigerators Master
  • 1,714 Answers
All newer models have a 'defrost timer' which melts the frost every 24 hrs. This is probably the problem, you will need to change the timer.
Posted on Jul 18, 2009
Maytag dual cool
Frost buildup in freezer is an indication that there may be air being drawn into either the fresh food section door seal or the freezer door seal. Your model has a 61005543 Air Damper
That may also be either defective or stuck in the open position due to frost buildup. You are just going to have a look behind the rear wall of freezer to see what is going on. Unplug first before servicing. If you would like me to upload a Service Manual please let me know, John Tripp Appliance 911
Contact Me Here
Mar 09, 2014 | Refrigerators
MCBR1020W is the model number for the refrigerator in my apartment. The refrigerator fresh food unit is not getting cold enough to keep food cold, this results in food spoiling. What could be causing this...
You could have the lack of air flow or a door seal problem. Could you check the freezer for me, look for frost on the back wall. If not frost, is the fan running in the freezer?
Please get back to me
Sep 08, 2011 | Magic Chef Refrigerators
Hello, actually my Maytag refrigerator is 22 cu ft. bottom -mount freezer. I'm pretty sure my freezer is the frost less kind but it has started getting frost and almost snow in it. I was just wondering...
Hello
Any freezer will accumulate frost on walls etc, eventually.Mostly in the summer when there's more moist air and door openings. The fan is supposed draw all moisture to the evaporator coils so you won[t get the frost , So if it is excessive check to make sure refridgerator compartment is keeping cold.If it seems warm to you,you probably have defrost issues.
If ok ,then check door gaskets for air leaks ,(excess moist air gets in).Or excess food ,especially at bottom might block some air flow.
regards
Jul 28, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
My fridge quit working.Freezer still works,cold air just not making it up top to the fridge.any ideas??
Most likely you have a defrost problem. The frost is building up on the evaporator coil causing a restriction to the flow of cold air from the freezer to the refrigerator.
Dec 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Both refrigerator and freezer are not cooling. Can hear that it is running, just not getting any cold air.
If there is no frost on the freezer inside rear wall , then the problem is the overload/relay , mounted on the compressor , with 2 or 3 wires going to it . On a Maytag , you probably have 3 wires . This part is easily replaceable . If you had given the model number I could have given you the part number .
If there is frost on the rear freezer wall , reply back as this is a defrost problem which requires a longer and more descriptive answer . With the complete model number .
Oct 15, 2009 | Maytag Refrigerators
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
Not cold enough
posible defrost not happening, air is not sirculating down to bottom compartment due to frost buil up
Oct 18, 2007 | Maytag MBF2256H Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
