Question about Acer Computers & Internet
I am trying to hook up an additional DVD RW drive to my Acer Aspire Computer but the cable connections are different than the usual IDE ribbon wire connectors in a regular computer. How do I do it?
  • 30 Answers
What do you mean by unusual? if it is smaller, i think it is SATA cable. If your motherboard have built in support for SATA technologies, you can get it one.
there are also another alternatif, such as you can get PCi bus IDE/
SATA interface card. But I cant guarantee it can be detected before BIOS. because it required driver to be loaded, so if you want to use it only for burning DVD's or CD's this is better way.
Posted on Jul 20, 2009
Set up HARD DISK
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=106&MenuID=24&LanID=0
The ECS P6STP-FL motherboard uses IDE (PATA) harddrives, and optical drives. (CD/DVD drive)
IDE 1 is for the Harddrive.
IDE 1 is the 40-pin connector that is closest to the Ram Memory slots.
(Only 39-pin are used, however)
IDE 2 is used for the optical drive/s.
IDE 2 is next to IDE 1, and is further away from the Ram Memory slots.
The IDE connectors on the motherboard, have a Cut-Out on one side. A small square cut-out.
This is for the Locating Lug, on the flat IDE ribbon cable's, connector.
This makes sure that Pin 1 in the motherboard connector, is lined up with Wire 1 in the flat IDE ribbon cable.
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
The Locating Lug shown in this example, is two 'ridges' that are separated. Some designs just use one solid block.
IF, there is no Locating Lug;
Look for the faint Red stripe, on the side of the flat IDE ribbon cable,
http://en.wikipedia.org/wiki/File:Nappe.svg
This stripe denotes the side, that number 1 wire is on.
Motherboard installed in computer case, the red stripe on that flat IDE ribbon cable, goes DOWN.
Down towards the Bottom of the motherboard.
When connecting to the Harddrive, and there is no Locating Lug on flat IDE ribbon cable, the Red stripe goes towards the power cable connection.
This applies to the optical drive (CD/DVD drive), and Floppy Disk Drive.
(34-pins for a Floppy Disk Drive. Cable is smaller in width)
Now, there is a different method of connecting a Harddrive, or optical drive, in relation to the flat IDE ribbon cable.
Depends on if the flat IDE ribbon cable is a 40-wire cable, or an 80-wire cable. You can use Cable Select setting on Harddrive/Optical drive; OR you can just connect the Harddrive, or Optical drive the correct way,
http://mikeshardware.com/howtos/howto_connect_ide_hd.html
Is the Harddrive recognized in BIOS Setup?
If your question relates that the Harddrive is not recognized, post back in a Comment.
Also post the manufacturer ID information off of the Harddrive's label.
Example for one type of Western Digital harddrive;
WD800AAJB
Western Digital 80 GB harddrive, and IDE (PATA)
With this information I can find the Cylinders, Heads, and Sectors.
Then guide you in entering it in BIOS Setup, IF needed.
"Press DEL to run Setup"
Press the Delete key to enter BIOS Setup.
AS SOON AS you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You will hear beeps. These are Stuck Key Error Code beeps, and it is YOU that is doing it. Ignore the beeps.
Best method for entering BIO Setup.
(The window of opportunity for entering BIOS Setup, goes by F-A-S-T! The above method will get you in)
Your problem statement leaves a hole in the time/space continuum.
Does not exactly state what your problem is
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 26, 2013 | ECS Elitegroup P6stp-fl Motherboard Cpu...
What cables to connect dvd writer model hap122 to computer
This model Lite-on DVD DVD writer has an E-IDE(PATA) interface.
It uses a IDE ribbon cable.
Oct 10, 2012 | Misc - MFG HAP122 8x Dvd-Rw dl 22x Dvdr...
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
Cd works open/ accepts the cd but i cannot locae the drive? I have an acer aspire 3680
check to cable IDE/SATA if loosen..also jumper configuration setting at the back of CD drive....
if single drive connected to your cable choose Master jumper setting...
May 26, 2010 | Acer (4432A-002) CD-RW Burner
Hello I hv an Acer aspire 4702z model z01 who's
remove the side of the computer and make sure the power connector is plugged in to the drive. if it is not then plug it in and the problem is solved. if it is the drive is dead or you have a faulty power supply try plugging in another power connector ... if it is an ATA power connector it has 4 wires and usually a white plug but not always white. there is also a dat cable called a ribbon cable and it looks flat 2 inches across and grey. if it is a SATA drive connector it will look like a thick cable with a black plug coming down from the top of the computer where the power supply is. There are 2 cables plugged in to the drive the bigger plug is the power cable the one with the smaller plug is the data cable usually orange or red. Make sure everything is plugged in if it is the drive is mostly dead. you can buy a new drive for around $25 at a computer store. easy to replace... i hope this helps
Mar 24, 2010 | Acer Computers & Internet
How do i install dvd rewriter with windows 7. There are different conections at the rear of the factory fit DVD...?
You generally only need 2 connections for an optical drive to work: Data and Power. Data will be either IDE (long 40 pin ribbon cable) or SATA (small [~1/2"] 'L' shaped connection for a much thinner ribbon cable).
Power will be either Molex (4-pin connector with red, black, black, yellow wires) or a SATA power connector that looks like a larger version of the SATA data connector).
All other connections are not needed, such as the small 4 pin audio connection which usually hooks up to the motherboard or sound card, but is only needed for analog playback of audio disks.
Dec 30, 2009 | Computers & Internet
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
Pioneer DVR-K17RS ATA ACER CODE=39
the dvd-rw doesnt work in mi acer aspire 5520-5912
May 18, 2008 | Computers & Internet
How do I install a DVD drive as well as my CD-RW?
mst...First, get your manual out. the drive must be set to be a secondary device unless it is not. You say you have only one IDE...did you remove the CDR? If you have a second IDE or other board connector, then this drive is primary on that. Now, did you install the drivers for the unit? You can use your CDR to do that or get them from the website of the manufacturer. Are there any bent pins on either the motherboard or the back of your drive? Somewhere in there is an answer.
If you have only one drive connector set, you can get a board which will allow you to setup additional drives. Ask your dealer.
Dec 17, 2007 | Computers & Internet
Computers & Internet Logo
208 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
