Question about Samsung PCL541R 54" Rear Projection Television
When i plug in my samsung pcd5415r monitor, i only show the timer light on which is red
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 18, 2009
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
My baby monitor won't charge - it's not even recognizing the charger as plugged in -- the red light doesn't go on any more??
shut it down and restart and see if it takes the charger ..usually there is nothing that makes the camera behave that way but the charger ..either being damaged or the plug does not makes contact well ..check the wire not to be damaged and try another charger with the same specs ..exactly the same ..It is possible to be damaged if you let it in the plug for a long time ..
If it shows out that the charger is not to blame ..than it is a mater of plug need to be changed cause is damaged ..In worse case just open it and hot wire if you can not get a plug to match ..
Dec 28, 2011 | Samsung Wireless Baby Monitor Camera...
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
What color plug where i ve got three colors blue,red,black
If I understand correctly, you are replacing a switch with the EJ500 timer.
You mention a 'plug'
The EJ500 has 3 wires: Black Red Blue.
If you are replacing a single-pole switch:
The switch has 2 wires, one of these wires is the Hot-from-breaker and the other wire goes to Load:
Timer-black connects to Hot-from-breaker.
Timer-blue connects to wire-going-to-Load.
Timer-red wire is capped off. Red is not used for single pole switch.
If you connect wires and your lights blink, then you put the red wire where the blues wire should go.
If you connect wires and lights do not operate, try reversing the blue and black wires.
I posted images of EJ500 wiring (the Intermatic EJ500 and ST01C have identical wiring
http://waterheatertimer.org/ST01C-program.html#ST01C
If you are replacing a 3-way switch, the wiring is more complicated.
The EJ500 can not replace a 3-way switch wire-for-wire.
Diagrams on link above show wiring for 3-way.
Add a comment if you need more help.
Nov 10, 2010 | Intermatic EJ500C - Indoor Digital Wall...
How do I set the self timer on the Samsung S730 camera?
Press the self-timer button (right-arrow on the circular multiselector) until the desired mode shows on the monitor. Your choices are 2 seconds, 10 seconds, and double. Press the shutter release button to start the timer.
Full details are in the "Self-timer/Right button" section in the manual, page 27 in the edition on Samsung's web site at
http://downloadcenter.samsung.com/content/UM/200803/20080324103057703_English.pdf
Aug 03, 2010 | Samsung Digimax S730 Digital Camera
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
My tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
hello sir,
please sir solve my this problem.
my tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
Dec 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Shut down, no pic/no sound just the red timer light
You need to replace the lamp. you can do this yourself.
May 26, 2009 | Televison & Video
Black screen and red timer light is on
It may be the problem of the Dish connection or stablizer. Remove the stablizer and connect the Tv direct to switch board and re connect the dish connection. Then switch on the TV it will work.
Nov 04, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
