Question about Dometic Rooftop RV Air Conditioner
AC won't run on low speed
Have Duo-Therm 59516 and when the fan spped is set to the low setting, the AC won't run nor will the fan.
  • Dometic Master
  • 6,674 Answers
It may not be wired for low & high fan mode. If it always did before, then yes there's a problem.
Posted on Jul 19, 2009
What size ac 59516 331
15,000 BTU. Here's a link for you. http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Air%20Conditioners%20-%20Vehicles/Duo-Therm-HP_installation_EN.pdf
Jul 13, 2014 | Dometic Rooftop RV Air Conditioner
Hello, I have a duo therm ac unit, the fan works fine in all the Fan only speeds, but when the ac is selected, the compressor comes on and the fan drops down to less than half speed. you can hear the fan...
Check incoming voltage circuit and wiring for proper gauge wire etc, and have compressor start capacitor tested, or replaced. I'm curious as to why circuit breaker didn't trip in panel when compressor causing so much current draw, that's reason for checking wiring etc to AC circuit.
Sep 14, 2011 | Dometic Rooftop RV Air Conditioner
Hi Everyone. Quick question.. I have 1999 Plymouth Voyager. And for some reason my control switch to the ac won't work on low. It has 4 speeds. It works only on full blast. Im new to this. I just want...
I think you are referring the fan control switch. Normally the fan has to work before the AC will turn on.
So if the ac is working only on higher spped settings, you need to confirm if the fan is actually working at the low settings.
Jul 27, 2011 | 1999 Plymouth Voyager
I have a Dometic P/N Duo-Therm Model #59516-531 that started running more and more to cool my RV 5th wheel. I checked filter, drain, and noticed the unit was icing up. I turned off AC and let fan run to...
It is probably low on refrigerant. You can only check this if you have a set of gauges. Otherwise, take it to an air cond company and they will check it for you.
Jul 21, 2011 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
324 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
