Question about Apple iPhone Smartphone
The bottom part of my screen is not working
If i press down really hard it sometimes slides but then none of the functions on the bottom work
2 Suggested Answers
  • 8 Answers
SOURCE: iPhone bottom edge only allows slide functions.
(For restore issues) When hard resetting the iphone unit, sometimes the 2 button reset will not work to force the restore mode. In this situation you should hold the 2 buttons until the display turns off. Then hold the HOME button and while holding it in, plug in the USB cable (powered- ie: plugged into AC adapter or computer USB port). This will power on the phone and bring up restore mode in itunes. iTunes will produce a message which says: "iTunes has detected an iphone in restore mode" -your friendly neighborhood MacGenius from the Apple Store
Posted on Dec 12, 2009
Camera comes on. screen shows OPTIO AND AT BOTTOM V1.01 THATS ALL- none of the funtions work. camera won't shut offf. have to open battery cover to shut off.
If you can get into the menu system, find "reset" in the set-up menu. If not, remove the card and battery...press every button....leave it alone for 20 minutes...insert the card and then the battery...turn it on.....this is called a "hard reset" and sometimes works.
Jul 17, 2011 | Pentax Optio 50 Digital Camera
I have a red key on bottom left side of screen. Have volume but no picture. None of the controls work on tv or remote.
Hello
Your TV is locked.
The Child Lock feature prevents unauthorized viewing of the
television. To activate, press and hold the Function key, and then
press MUTE. you should see a key symbol appear on the screen.
This will lock out all remote functions (except for Standby). To unlock
the TV, press and hold the Function key and press MUTE. This will
unlock the TV. Please note that the only way to activate or deactivate
the Child lock feature is via remote control - please insure that it is
stored securely.
Jul 11, 2011 | Apex Digital AT1314DV 13 in. TV/DVD Combo
I have an Lg Banter phone. and the screen is black and wont show me anything. The phone is still operating but the screen is not functioning right. Sometimes the screen will work but when i go to slide it...
I have the SAME PROBLEM. i'm so sad I'm 13 and i PAYED for it.. :(( This isn't really a solution, just saying your not alone. whenever i slide my keybaord out my screen gets so messed up and flickers and dies.
Oct 29, 2010 | Cell Phones
I have a Compaq presario CQ61, an when i turn it on the screen is black other than some really dim writing i can hardly see. Help?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 23, 2010 | Compaq Presario Notebook
The screen on my garmin is not working
Hello :
Hard resetting could solve the problem .
Here is how to hard reset your device :
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 17, 2010 | Garmin nuvi 205W GPS Receiver
IPhone bottom edge only allows slide functions.
Try a hard reset on the iphone. Hold don both the sleep/wake button at the top right and your home button at the same time. Continue to hold both buttons for about 20-30 seconds (do not slide to power off) until you see a white apple appear. Let go once you see the apple log appear, wait for phone to power cycle back on. If that doesn't work, try a restore. You must connect to itunes, choose restore as new. If it doesn't work after that, you'll need to get a replacement.
Dec 03, 2009 | Apple iPhone Smartphone
Iphone 2g stuck at slide to unlock screen
Seems like the digitizer(which sense the touches) is not working. Replace with a new one and you'll be good to go
Jun 18, 2017 | BoxWave Corporation Apple iPhone 2G...
Removing front cover to fix non-closing dispenser door
If your talking about the disp/foutain cover for the ice door chute not closeing problem heres how its done.
1 That cover is plastic and plastic flexs.
2 There should be two notches in the bottom area of cover. Insert flattip screwdriver in either one and pry out towards you. Bottom should pop off and top then slides up of tabs in door.
you can also try pushing down on top of disp cover when prying at bottom or pressing down really hard on fountain cover till part sortof flexs/slides down a milimetter and pulling towards you. The pressing down and pulling is down at bottom of cover inside disping area.
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
4. The Pocket PC resets and powers on.
Mar 18, 2009 | HP iPAQ HX2415 Pocket PC
Apple iPhone Smartphone Logo
52 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
