Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
My weed eater will not run more than 30 seconds before it dies. Once it starts to idle it dies
  • 130 Answers
Rebuild carb that will fix your problem
Posted on Jul 18, 2009
My murray m2510 gas weed eater runs at idle but when i go past fast idle it wants to die. i put a new spark plug in it, it didn't change. what could be the problem? it started doing it last fall.
Sounds like fuel problem. You may want to check the vent on the fuel tank. It can get clogged and won't provide enough fuel to run at higher rpms. I'm not familiar with that engine, but its a problem I've had in the past with weed eaters and chainsaws.
Apr 07, 2016 | Fast Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Toro weed eater starts but then stalls out
    A few things to check, clean or replace:
    • fuel filter - located inside the fuel tank
    • Spark arrestor - located at muffler
    • Spark plug
    • Carburetor
    Mar 08, 2014 | Garden
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
    Hard to start weed eater
    check for proper starter proceedure.some models are very specific to starting proceedure.if the equipment does not run to warm up or if the chike sequence is improper it will not start
    Sep 09, 2012 | Stihl FS 85 Weed Eater
    John Deere weed eater problems
    remove the muffler and run it if it runs good after that open the muffler and clean the screen inside
    Apr 01, 2012 | Garden
    My Ryobi weed eater loses power at working speed after 5 minutes.
    you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
    Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    Poulan Pro weed eater won't accelerate.
    check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
    Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
    726 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
