Electrolux 9.46 cu. ft. / 268 liter Upright Freezer EUC3003
Problem for Electrolux 9.46 cu. ft. / 268 liter Upright Freezer...
Alarm on
By hectormillie on Nov 19, 2007
on the display, the alarm light and the super light is on and where normally the temperature would display, it now says 55. Also while there is alot of ice at the top of the freezer, the lower part of the freezer seems to be less cold than usual.
Best Solution
posted on Dec 04, 2007
Helpful)
Bob from LI
Rank: Guru
Rating: 85%, 740 votes
hector...this sounds like icing up! First thing is to defrost this unit. The ice is preventing air flow over the coils. Shut down and get warm air to the coils. Then, let everything dry. If you leave off and open for 2 days, this will do it. Causes: humid conditions, 'window shopping' or bad gaskets. If the gasket surfaces are dirty, clean them. Test any questionable areas by taking a 2-3 wide strip of paper and close the door on it. If the paper pulls easily, the gasket is bad.
Now, clean out the condenser coils. They are located in the back or under the unit and are always painted black. Then, have a look at the compressor. It is that big black thing in the bottom with pipes sticking out of it. Look at the larger pipe. When you start the unit, it should frost and then either dry off or condense water after about 5 minutes. If it stays frosty or is not cold, you need gas. If the unit passes all these tests, you may have a defrost timer issue. Let me know.
Was this helpful?
Yes
No
Popular Solutions for Electrolux 9.46 cu. ft. / 268
Questions and Unsolved Problems for Electrolux 9.46 cu. ft. / 268
Do you recommend Electrolux 9.46 cu. ft. / 268 liter Upright Freezer EUC3003?
Answer
Answer
broken ice maker, ice door has a loose part-kitchenaid
Answer
light doesn't work; bulb is good
Answer
my frigidaire freezer door was left open, on the bottom there is a yellow and red lite both are on,... (More)
Answer
i have a rangemaster fridge freezer,it has the ice water option on the front, as well as the fridge... (More)
Answer
The freezer temperature information lights started flashing up to and including -18'C. Considered it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Freezer Experts
Top Refrigerator Repairmen
in Tulsa, OK
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
