Question about Karcher 2500 PSI Pressure Washer
Runs fine gc160 wont give me any pressure. i took the pump apart and cleaned it then put it all back together the pressure was intermediate but now nothing at all
    New Friend:
  • 47 Answers
If you give us a bit more information we may be able to assist!
is it a pressure washer you are trying to get running.
the number you give is the model number of the honda engine. 5.5 hp honda domestic use.
what does the pump look like. etc
Posted on Jul 19, 2009
I took apart my sewing machine, Brother CE1100PRW, to clean, and "Error 1" would not go away, please help.
Brother says:
The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
An E1 message appears on the panel Brother
Apr 13, 2018 | Brother Sewing Machines
Why won't my pressure washer start?
Im currious what on a pressure washer required "cleaning" what were you running thru it other than water ?
do you think you might have dissasembled something on engine part and might not have assembled it back quite right?
May 03, 2014 | Stanley 2350 PSI 2.3 GPM Gas Pressure...
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Jan 10, 2018 | Craftsman 25cc Gas Line Trimmer
F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Aug 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
Dishwasher will not drain
We took it all the way apart and cleaned it really well in the bottom of the dishwasher. Then we put it back together. Then we removed the hose from the disposal and suctioned it with the wet/dry vac to remove any clogs, then put that back together.
Ran dishwasher with Tang in both powder cups to clean it, and it's running fine now.
Apr 20, 2008 | Dishwashers
Dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Jan 30, 2008 | Dishwashers
Low fog output
I had the same problem with an American DJ, I removed the pump took it apart and cleaned it. It had a stuck valve in it. It now works fine.
Oct 27, 2007 | American DJ Dyno-Fog-II Fog Machine W/...
Karcher 2500 PSI Pressure Washer Logo
438 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
