Question about HP Officejet 5610 All-In-One InkJet Printer
I haven't used this to copy for a few weeks and it won't copy. It won't feed and it won't scan. It locks up and I have to pull the plug to reset it. It will however, print from the computer. Help?
I printed a screen off of the internet. Then I was able to shut of printer sucessfully. I then tried to copy again after I started it back up and it printed. Yeah! I think there was some kind of glitch that was corrected after I printed and shut the printer off. Before, I was only able to shut it off by unplugging the printer.
Posted on Jul 22, 2009
Feed dogs lowered can't raise material not feeding thru
Is your machine mechanical? If so, sounds like the feed dogs are stuck in the lowered position. Needs good cleaning and oiling.
Perhaps this will help:
The feed dog knob won turn don think anything is broken haven used the...
Dec 30, 2015 | Sewing Machines
How do I raise the feed dos
Consult your owner's manual. There is a switch, lever, or knob somewhere on your machine that raises the feed dogs. If they are stuck in the down position and your machine is mechanical, could very well be it has seized due to lack of cleaning and oiling.
This may be helpful:
Fix vapor lock
Hi, This sounds like the fuel pump needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 24, 2017 | Ford Crown Victoria Cars & Trucks
HP deskjet 1056 won't feed paper
I just fixed mine. The paper would feed part way then jam and twist a little off center. When I pulled the paper out there was a crinkle on the bottom edge, left side, about 2 or 3 inches in. I did some looking with the scanner removed a saw a plastic tab like the ones that hold and feed 1 sheet at at time. This tab was located inside a little "box-like" thing on the underside of the printer. I turned the printer over. There are several openings/ holes in the 'box'. You can take a pencil or similar object and slide a flat 'tab' that is inside the 'box'. You will see a small spring in one of the holes. Slide the flat tab toward the spring until it locks in place. My printer now works fine. To me the 'box' mechanism looks suspiciously identical to an analog counter wheel. If it is, then it is counting the pages and then engaging the tab to cause a paper jam so you will buy a new printer. Similar things happen electronically to my HP psc 1210 & my Officejet 5610. They will stop scanning or printing, give "no cartridge" error codes, etc... I unplug them for a few weeks and it's like they are new again. PS, if the printer can't talk to HP it will work longer.
Apr 16, 2013 | HP DeskJet Office Equipment & Supplies
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
HP 3310 printer will not scan a fax or slides
no problems man
:just take out the catriges..plug outthe power cable ....then plug it bacvk in after 20 secnds,the printer will ask fr printer catriges ,puthem back in and try to perfom fnctions ,still problem persists ,follow following steps
:just go ahead and take ou the power cable
and press and hold # and 3 fr 30 seconds
while pressing them plug in the power cable
:similarly perform with # and 6
:ur problem will be resolved
Jun 28, 2009 | HP Photosmart 3310 All-In-One InkJet...
Paper feed jamming
check the back of printer and see if there is door u can open. Most likely there is a paper jam u cant see.
May 24, 2009 | Canon PIXMA MX310 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
