Question about Home
Can a K-8549 diverter be installed in a wall?
  • 308 Answers
No where in the instructions does it say that you can not, I don't see a problem with doing so.
Posted on Jul 21, 2009
Kitchenaid diswasher model kudw03ctbl2 leaking from pump
The diverter valve at the bottom of the machine is a valve that diverts water to the spray arms. It's a notorious part for going bad and causing water to leak out of the bottom of the unit.
Mine was corroded badly at the switch and leaked at the seal. I purchased a new diverter and removed the unit from the cabinet. Once out I laid down a blanket and tipped the unit over. You can remove the diverter with two screws. Be careful that the electricity is properly off. I did not unhook mine but made sure the switch was off on the wall.
The factory connectors were OK on one side but corroded beyond recognition on the other side. I ended up cutting off the connector and soldering the wires to the small PCB that had the switch on it. The seal is in the bottom of the unit and is a rubber spring type seal. If you just install the new part it will still leak. You need to carefully pry the seal out and clean it up. They install the thing with the spring seal facing the wash water. It gunks up and clogs and the unit eventually leaks. The leaking corrodes the switch and the diverter then fails to properly move.
Carefully inspect and clean the seal. I re-used mine by first using SuperLube PTFE food grade grease on the shaft and seal face. I installed the seal with the spring side TOWARD the diverter. They install it upside down from the factory. Use plenty of lube. The rick is to push the seal all the way down on to the new diverter. The shaft for the diverter has a groove and the combination of the lube, the proper orientation of the seal and that groove keeps the water out.
Once installed on the bottom the seal will be forced back into it's bore on the bottom. Installing the seal into the bottom first does not work. It will leak. Use the above method and it will only push the seal in enough to get good engagement with the seal as well as go in just far enough into the bore to keep it from leaking.
Works like a charm now.
Oct 14, 2013 | KitchenAid Dishwashers
When filling up with water it is leaking from the bottom
I think it may be leaking at the pump. Pull it out from the wall take the back off it and watch it go through a cycle
Feb 21, 2013 | Hoover 24 in. DT999 Free-Standing...
The diverted valve will not turn ,it worked when installed but won't turn now .how do I replace the diverted.
The spout unscrews from the wall.Take that part off and bring it to the store to match it.Then just screw the new one on.
May 18, 2011 | Moen 2995 Chateau Three Handle Standard...
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
Kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Jul 22, 2009 | Plumbing
I'm installing a surround system in my basement. My question is where else can i install my center speaker? I'll be installing an electric fire insert with a large T.V. above on a 6ft stone tile wall. I'll...
Hi, you can tell your amp there is no center speaker and the sound will be diverted to the left and right or for better sound if you can get a custom install speaker built into the wall or if the tv is high up on the wall put your center in the ceiling.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Home Logo
19 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
