Dosent reach desired temperature its too warm
    Problem Solver:
  • 9 Answers
A 5 ton system is only 5 tons if it is at 90 deg. outside. As it gets hotter, the true btu output gets less and less. If you are in the southeast with the humidity, this is the common issue, if not -you may have sizing issues.
Posted on Jul 18, 2009
Does this model shut off automatically when the desired room temperature is reached or does it function on a low medium high type of thermostat that continuously runs? IR 3 0 p m d g - 1
if it is an inverter type air conditioner ( make not indicated) the unit runs continually but the compressor delivery is reduced thereby reducing the load on the motor
as the room warms up again the compressor starts to pump more gas to keep the room at the desired temp setting
older types shut the compressor down and restarted when the high temp was reached
Jan 19, 2018 | Heating & Cooling
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Heater not achieving proper temp. on drivers side
if youre smelling antifreeze then its a sign that the heater core may be leaking..
Jan 01, 2014 | 2006 Land Rover Range Rover Sport
F3 error code when warming up - the unit does one of two things 1) stops before reaching desired temp - 2) reaches the desired temp and then shuts off
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | GE Profile JT952 Electric Double Oven
My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
How do you set the temperature
If you have an air conditioner with a temperature display, use the up or down arrows on the touch pad to change the temperature setting.
However, if you have an air conditioner with only a dial that goes from 1 to 8 (or whatever number), turn the dial up as high as it goes and put the fan speed on high. When the desired comfort level is reached, slowly turn the dial down until the compressor just shuts off. You will be able to hear when this happens.
If the temperature gets a bit too warm turn the dial up in small increments and wait an hour or so to see if your comfort level is reached.
Jul 03, 2009 | Heating & Cooling
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Sep 29, 2008 | Haier Refrigerators
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
