Question about Philips Televison & Video
Magnavox model 51mp6100/37, the power light comes on but no picture or sound. a strange niose comes from the back panel
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
If its a chirping sound the convergence chips are shorted. I learned this the hard way.
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Posted on Aug 09, 2009
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Feb 15, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
42" magnavox lost picture but
Power supply problem. If you have electronic experience pull the rear of the panel and look at the power supply and check for bulged or leaking or busted caps replace them and i will probably be good to go. if you cant do component level repair order the whole board and also dont kill yourself - tv voltages and amperages are strong enough to kill a human.
thanks,
Michael
Feb 07, 2011 | Televison & Video
Picture but no sound on magnavox tv
My tv which is phillips has sound but no picture,there is two red lights on the front that comes on ,one is for power but what is the other one
Jun 20, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
Phillips 60PP9202/17 F No picture No sound
Does the power light still work when you have the above problem? If so check the site www.tvrepairkits.com. They should have a repair kit for this model.
Sep 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
