Defrosted freezer -
Melody, It appears that possibly either the kids accidentally turned the freezer off, or something being taken out/put into the freezer, got pushed into the control knob and caused it to turn off. (Just trying to help the kids avoid taking the full blame with that one!)
The good news is that your freezer is probably fine and just got turned off somehow. You can put it back to the middle setting and adjust it from there to get the coldness you want for whatever you're keeping in it, (meats, ice cream, veggies, etc.)
The indicator lights are to let you know that you have power going to the freezer and the other one lets you know that the freezer is working and the compressor is operating. I'd keep an eye on it for the next few days though, just to make sure that everything is working the way it should, just in case. You can take an old plastic milk jug (1 gallon size) and fill it with tap water and put it in the freezer on the middle shelf. If after 3-5 days, the temperature is staying cold enough, the jug of water should be fully frozen. You can also put in a load of bread and see if that freezes nicely after a day. If the above items are properly frozen after 1 and 3 days, then your freezer is working properly and the culprit was very likely, just the control knob getting turned off, somehow.
I'd also suggest that you might want to lock the freezer, if your's has one, to help minimize any chances of the settings getting changed, etc. Of course, if you've got ice cream and kid snacks stored in there, then your children will keep looking until they find the key anyway!
You should check any of the food items you had stored in the freezer and if they got defrosted completely, you'll likely have to toss it all out, the only exception is bread, (which is typically not much good once it's been frozen anyway), but can be used to "fill-up" the freezer to keep it operating efficiently when you don't have much stored in it. I usually just mark the bags of old thrift store bread with the date I put it in the freezer and toss it after a year.
Bread is an inexpensive way to load up the freezer so it runs better and helps save you some energy costs, even when you don't have much other higher priced food in it.
I hope you find this Very Helpful and best regards!
