Question about Panasonic TOUGHBOOK CF-18 Tablet PC
When I try to boot my Toughbook CF-18, the power light turns on(illuminates green), as well as the brightness adjust(sun shaped icon illuminates green) but nothing shows onscreen. I've tried using an external monitor as well with no luck. No beeps, no screen flicker no HDD activity appears to be happening either! Help!
  • Ray Andersson May 11, 2010
    How did it happen? Did it work before?
freetek
  • 5568 Answers
SOURCE: cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Posted on Oct 02, 2008
JLBeertender
  • 56 Answers
SOURCE: Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Posted on Apr 16, 2009
  • 979 Answers
SOURCE: am in need of touch screen drivers for tough book CF-18
try driverguide.com
Posted on Jul 09, 2009
SOURCE: CF-18 GPS installation
http://toughbookcentral.com/category/guides
Posted on Jul 10, 2009
  • 3 Answers
SOURCE: Toughbook CF-18 Supervisor Passwd
Toughbook CF18, CF-18
How to remove the BIOS Supervisor Password:
Open all covers and openings. Remove hard drive and battery. Remove bottom of notebook. Many many tiny screws.
Now look towards the rear of the notebook. You will see 2 plugs both have a red and black wires. The one with the much smaller wires and connector is the BIOS battery. Use a pair of needle nose pliers and remove this plug.
Leave it off for 5-15 minutes.
Leave the BIOS battery plug off. Replace the laptop's main battery. Leave the hard drive out. Turn the unit over and turn it on.
Press F2 when the screen comes up. POOF! NO PASSWORD!
Go to Security and disable the password. Save configuration. Turn off the notebook. Replace the small connector. Turn it back over and turn it back on. Press F2 and verify that there is no password. Go to Security and Disable the password again. Save the configuration.
Put the bottom back on. You're done.
NOW FOR THE BAD NEWS!!!
Your hard drive is now dead. Replace it. When a supervisor password is used it locks the hard drive to that password. There is NO WAY to recover the hard drive. It is called an ATA security password. Without the ATA password the hard drive is completely useless.
Posted on Oct 10, 2009
Panasonic CF-18 wont turn on but power light comes on
Have you try cleaning and reseating the connectors, specifically the battery, the hard disk, and (next will be easier when you'll get the hand on a CF-18 Service Manual http://www.toughbookdrivers.com/drivers/cf-18/), the memory board, and the display ?
Nov 14, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18 toughbook
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Wireless connection problems
Not exactly an ideal solution, but why not buy a cheap USB wifi card, install the software, and use that to access the net? Usually less of a hassle than trying to repair an onboard wireless device, and the plug-in ones are now quite dependable, and cheap.
Jan 07, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
95 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
