Question about Apple iMac G4 Desktop
My iMac G4 turns on and goes to the grey startup screen with the apple and loading circle, but stays there, and gets stuck, and after a few minutes shuts off on it's own.
    Scholar:
  • 50 Answers
RESET THE PRAM!
Hold down the command-option-p-r keys, and turn on the computer. Keep holding down these keys until you hear the "bong" four times. Do NOT LET UP ON THE KEYS until you hear the bong four times. Then let go.
If it still does not boot up, try booting up with the shift key held down. This causes the mac to boot into safe mode. You have to hold down the shift key until you see something like "safeboot" on the startup screen (not the grey screen, but the next one.)
There could also be a hard drive directory issue. While reinstalling the OS can help this, you should try DiskWarrior first. That program has saved my backside many times. It can repair the directory without wiping out all the contents of the hard drive.
There could also be a logic board problem. That gets a little tricky to fix on your own with this box. The home repair trick on that is to unplug the computer, disconnect the power supply cable from the logic board, and remove the battery. Let the computer sit like that overnight, re-assemble it, and start it back up.
Posted on Jul 22, 2009
    Scholar:
  • 151 Answers
You may have to reinstall you OS e.g. tiger, leopard with the disks that came with your computer. that should solve your problem
Posted on Jul 19, 2009
Why does the screen of my iMac G4 stay black on start up?
Test the system on an external monitor. If OK, replace the screen.
Jun 09, 2012 | Apple iMac G4 20" Mac Desktop
Apple iMac g5 mac desktop stuck on white screen with apple no circle
Try two or three times, make sure there are no add ons usb
Mar 23, 2012 | Apple iMac G5 Desktop
My iMac g4 1ghz wont boot
First hold down the right hand shift key down when you start, this does some housekeeping, The next step is if you have an install disk or tiger disk then start up from it by holding the "C" key down when starting and inserting the dvd, if this loads then go through the install menu, dont worry you do not need to actualy install just select language and then you get to a screen where you can select utilities from the menu bar, then select disk utility and repair permissions, after that do a repair disk then quit disk utility and change the startup disk back to the hard drive and restart, if for some reason you cannot repair the disk, this refers to the catalogs it uses to keep track , not the data itaelf, in that case you need a 3rd party utility like Disk warrior.
Feb 24, 2010 | Apple iMac G4 Desktop
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
Computer won't start up correctly
Considering you have tried the Safe Boot mode to correct this, try to resolve this from the hardware side:
Procedure #1:
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the star tup sound for the third time.
• Release the keys and allow the Macbook to start up.
If the iMac still does not start up to your Desktop correctly, go on to the next procedure:
Procedure # 2
-PMU RESET-
The Power Manager is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
• If the computer is on, turn it off.
• Disconnect all the connections going into the Mac except for the Power cord.
• Once all connections have been disconnected, remove the power cord from the iMac.
• Wait 1 minute.
• Reconnect the keyboard, mouse and power cord back into the computer.
• Press the Power button to restart the iMac computer.
• Observe if it starts up to the main desktop this time.
If it does not however, you may have an issue with your current Mac OS X directory or the issue could be hardware related.
Here is a comprehensive reference for you regarding Additional Troubleshooting for Blue, Gray screen issues and more, that you can also review:
Apple Support Link:
Startup Issues for Macs
If all else fails, you may need to visit your local Apple retail store Genius bar or local Apple-authorized service center in order to have your iMac at least diagnosed to find out what the core issue is.
Regards,
-Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
G4 imac desktop won't boot up to show icons
Are you running OS 9? Are you referring to the loading of extensions at the bottom of the screen on boot?
Jan 09, 2010 | Apple iMac G4 Desktop
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
Canoot get Mac to boot up all the way
there is a hardware fault or full hdd ...
thi guys will help Micromen - London
Aug 30, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
My powermac g4 startup problem - grey screen and folder+blinking
when booting immediately after the first chime before the grey screen hold down keys (apple,option,p,r) allow the computer to restart if it still goes to that blank screen restart again and this time hold down only the (option) key or maybe (option,s) on that model try option key first then select the main start up disk from the menu and click the arrow underneath
Apr 21, 2009 | Apple Computers & Internet
Apple iMac G4 Desktop Logo
481 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
