Question about Maytag Ensignia MAV4758AWW Top Load Washer
After start washing the clothes a burned rubber smell was coming out from the washer.
  • 864 Answers
Drive belt is failing and should be replaced. check by looking underneath the washer
Posted on Jul 18, 2009
My Beko washing machine has a smell of melted rubber and I found black bits on the drum. None of the clothes have been damaged but they do smell a bit. Is it overheating or something?
hi Alyson.
this is what i found on the internet.
WHAT'S CAUSING A BURNING SMELL IN YOUR WASHING MACHINE? If you notice a burning smell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The Burning Belt Smell Many top loaders are direct drive. This means they do not use a belt. The motor is directly connected to the transmission.
In Whirlpool and Kenmore models there is a rubber coupler between the motor and transmission that takes much abuse. It's very common for the fingers or the rubber itself on the coupler to break. A clicking noise with no spin or agitation along with a slight rubber smell are symptoms of this problem.?DIY repair is possible. Older models may also have belts that can be tighted or replaced
The new Whirlpool or Maytag washer can often be fixed without calling for repair.
To work on a top load HE washer pull the empty unit away from the wall. Drape a small rug or towel over the control to minimize damage to the wall and the panel. Lean the unit against the wall and the bottom will be clearly visible. Lie on the floor and note if there are rubber pieces or shavings under the washer. The belt may be rubbing against a plastic guard attached to the motor. The solution is actually quite simple: If the belt is shredded or worn you need to replace it. You can call a repair person or, if your washer is under warranty, the manufacturer. Or, if you or someone you know is handy, you can do it yourself!
Electrical Problems If your washer smells. The first thing to do if you notice an electrical smell in your washing machine and not a rubber burning smell, is to unplug the machine and call the manufacturer or a repair person.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
or go to this link might help you to find out more.
washing machine has smell of melted rubber and found black bits on the...
Nov 29, 2017 | Beko Washing Machines
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
Other Causes
Nov 07, 2010 | EuroTech Washing Machines
Burning smell from washer
YOUR DRIVE BELT MAYBE WORN AND NEED REPLACEMENT.
Oct 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
When drying rubber burning smell from inside Equator EZ 3612 CEE
If you are still wanting to know the reason, it may be that the door gasket has warned off and may need to be replaced.
Apr 04, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Maytag Ensignia MAV4758AWW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
