Question about Sharp 27H-S60 TV
Vertical reduzida tv ta funcionando mas com o vertical reduzido
  • 1,694 Answers
Re: vertical reduzida
Solder pins of vertical output circuit, solder any and all bad connections.Other experts = please translate in Spanish.....T.
Posted on Nov 20, 2007
0 characters
3 Points
Sharp , trueflat model of TV , On screen mas sage come is high voltage, and homes light reading is double unit in a day , what is the solution
Power supply regulator section circuit, inside the TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 07, 2016 | Sharp Standard (CRT) Televisions
2004 Toshiba TV 32A41 problem
to me its sound like your on the right track. there isnt a physical vertical hold adjustment. more than likely the vertical hold ic has failed. send me your email addy to and i will be more than glad to email you a service manual
Oct 25, 2007 | Standard (CRT) Televisions
Sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
Check the Flyback Transformer
and associated circuits.
If 2SK2996 is blown, it may take out the PWM IC and some components
that goes with it.
Let me know what you find or needs further assistance.
Sep 17, 2012 | SansuiM1315 TV
Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
Jul 10, 2009 | Standard (CRT) Televisions
como puedo deslaquear mi tv le puse una caja convertora y no se ve nada necesito algo mas grasias att, gonzalo mi coreo es
Mar 19, 2009 | PPI PTV19S19 19" TV
TCL TV picture too dark
try turning the light sensor off
Oct 20, 2008 | JVC AV32F476 32" TV
adjust the vertical hight with service mode. or adjust the liniarity V or replace the vertical filter or chk the+B volt ,solder the dry soldering point in vertical section ok i am Basheer my e male is ,,,,, ok by by
Sep 23, 2008 | Philips 27PT5445 27" TV
El chassis de synch, no esta funcionando adecuadamente. Probablemente loose connections around.Si puedes quitar el tunner board y resoldarlo, hazlo; Pero la solucion esta en el chassis donde esta el tuner. Tambien lleva unos panel conectado verticalmenet, esos hacen mucho falsos. resoldalos. Por ahi si tienes dudas escribeme Hechale ganas!!!
Jul 29, 2008 | Sony KP-46S25 TV
Toshiba 27AF42 27" TV Problem
hirizontal line problem
  1. please reduce brightness to avoid crt damage.
  2. h/ line is mainly due to failure of vertical section.
  3. please check the the following.
  4. supply to vertical section
  5. connector loose in vertical section
  6. print open in vertical section]
  7. parts connected to vertical section like capacitor,low va lye resistor& ic .
  8. hope this will help.
  9. good luck
Oct 12, 2007 | Toshiba 27AF42 27" TV
No vertical deflection
Never heard of this model/make. Must be a label TV How many pins and whats it start with ie TA-LA?
Aug 19, 2006 | NetTV DTV-29XF3 29" TV
Standard (CRT) Televisions Logo
44 people viewed this question
Top Sharp Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Sharp Standard (CRT) Television Expert? Answer questions, earn points and help others
