Question about Malber WD1000 Front Load Washer/Dryer
Does not turn on. Plugged in; has power. no pilot light...nothing.
  • 3,037 Answers
Can you confirm the model number of the dryer in question since I don't believe you are referring to the WD1000.
thanks
Benjamin
Posted on Jul 18, 2009
I turn it to pilot and hold it down and stick lighter inside and nothing lights
make sure u got gas, if u do then ur pilot orfice is plugged
Dec 18, 2015 | Heating & Cooling
SW4P won't light
Sounds like ignition problem check earth & power. If your getting a spark check pilot assembly
Apr 20, 2014 | Suburban 3 gallon Water Heater Pilot Sw4P...
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
Trying to hook up a pilot light switch to a gfi recp not having much luck with getting it to work properly i got 2 conductors from the panel and 2 conductors going to the gfi recp and on the switch i have...
It is unclear what pilot-light-switch is supposed to turn on-and-off.
Option A) pilot-light-switch is going to turn GFCI on-and-off
Option B) pilot-light-switch is getting power from existing GFCI circuit, and switch controls another Load (light, fan or motor) located elsewhere.
Add a comment at any point.
Bare copper wire always connects to green screw.
1) I have a Cooper pilot-light-switch in my office.
Black Hot wire from breaker always connects to dark-colored screw(s).
White Neutral wire from breaker box connects to silver-colored screw
Wire going to Load (light, fan, motor) connects to brass colored screw.
2) Two things happen when pilot-light-switch turns ON:
a) Pilot light turns on. This circuit is powered by black Hot wire, and circuit is complete with white Neutral.
b) Brass screw that had no power, is now powered.
The GFCI:
Hot from breaker always connects to brass-colored Line screw
Neutral from breaker connects to silver-colored screw that is opposite Line screw.
If other switches and plugs are going to be protected by GFCI, they connect to brass Load screw and to silver screw that is opposite Load screw
Option A) You want pilot-light-switch to turn on GFCI receptacle.
a) Wire pilot-light-switch as described above
b) Black wire from GFCI line-screw connects to brass screw on pilot-light-switch.
c) White wire from GFCI silver-screw-opposite-line-screw connects to any white Neutral.
Option B) Pilot-light-switch is getting power from GFCI receptacle AND you want pilot light switch protected by GFCI.
a) Black wire on pilot-light dark screw connects to Load screw on GFCI
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw
Option C) same as option B except pilot-light-switch is NOT protected by GFCI.
a) Black wire on pilot-light dark screw connects to Line screw on GFCI or any Hot wire
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw or to any Neutral wire
Nov 19, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Hi. i have a vermont castings radiance stove, RDV40. the pilot light went out and won't reignite. yes, the gas is on. i've followed the manual -- turning the control knob to pilot and pressing the ignition...
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
Aug 25, 2010 | Heating & Cooling
Gas Furnace - residential -found furnace off - pilot light off -
check ur venting first make sure its not plugged
Jan 01, 2010 | Heating & Cooling
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
Gas pilot not lit in dryer.
It has an electronic igniter,Just make sure the gas is turned on the the dryer(at the valve located behind it)and make sure the power cord is plugged in.
Please rate this a fixya
Feb 03, 2009 | GE DBXR463GB Gas Dryer
My street pilot c330 wont power up
I am continually amazed by how many people list there problems with only the barest of explanation. How on earth do you expect a reasonably informative answer when your total description of the problem is "my street pilot c330 wont power up"? OK, so tell us more! Did it work just fine until one day it stopped? Did you let it sit for 6 months and when you plugged it in again... nothing? Did you check the fuse in the power cord? Oh, you didn't know there was a fuse there? Read the book! If you want help from me, kindly describe in a bit more detail just exactly what the problem is, a bit of history of what, if anything, led up to the problem, etc.!!!
Jan 27, 2009 | Garmin StreetPilot C330 GPS Receiver
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
32 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
