Question about Aiwa Audio Players & Recorders
I have an AIWA CX-ZL100 stereo. The CD quit reading CDs. Have used a CD disk cleaner. Didn't work
3 Suggested Answers
  • 133 Answers
SOURCE: MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
Posted on Jul 24, 2009
  • 4234 Answers
SOURCE: Aiwa cxzr525 cd player. After loading under the
The clicking you are hearing is an attempt to focus on the disc. The usual cleaning discs don't work well. Try to gain access to the lens and clean itusing a cotton swab and alcohol. That will remove any film that remains on the lens. If that fails to resolve the problem, the optics will need to be replaced.
Dan
Posted on Oct 21, 2009
Testimonial: "Hello Guru, You were extremely helpful.After wasting my money on a disk cleaner which did nothing,the alcohol with a swab fixed my problem.Thank you!"
Where can i get a free user guide for aiwa cx-nmt520
gm rick hoffer go to this site then type in your model number good luck....http://esupport.sony.com/
Jul 08, 2012 | Aiwa Audio Players & Recorders
I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Apr 28, 2009 | Audio Players & Recorders
Remote Code Aiwa CX-NA505u
Does not play cds properly skips like crazy volume knob sometimes goes louder when i turn it down dosent read all cds eather whats the problem?
Mar 24, 2009 | Aiwa VX-S205 Combo
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
HOME STEREO SYSTEM CD PLAYER
I WOULD LIKE TO KNOW WHY AFTER PAYING WHAT I DID FOR YOUR ENTERTAINMENT CENTER THAT I WOULD HAVE TO PAY FOR THE REPAIR SERVICE PLAN?????? THAT JUST DOESN'T SEEM FAIR AT ALL TO THE CONSUMER. I WOULD LIKE THE EMAIL ADDRESS TO SOMEONE OF SUPVISOR POSITION. THANK YOU
INSTEAD OF CLOSING THE CD LOADER WITH THE OPEN/CLOSE BUTTON SIMPLY CLOSED IT BY CHOOSING THE TRACT NUMBER WANTING TO PLAY. SO FAR IT HAS WORKED. BUT WILL NOT WORK AUTOMATICALLY WILL TRY PROGM. THE REMOTE NEXT SEE IF THERE IS ANY LUCK WITH THAT PART.
THANK YOU
Jul 06, 2008 | Aiwa NSX-A115 Shelf System
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Feb 07, 2008 | Aiwa CDC-Z127 CD Player
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Aiwa Stereo System NSX-F9
insert CD lens cleaner first, then try to load audio CD if do not work change the lens
Nov 24, 2007 | Audio Players & Recorders
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
339 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
