Vizio E701I-A3 70" LED TV 1920x1080, 120 Hz, HDTV Logo
ronald bryson Posted on Sep 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Visio 70 in smart tv model #e701i-a3e and the tv goes blank for a few SE ones very 10 or so minutes then turns back on
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Sep 17, 2016
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986515
Points
237762
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
I have a 70 inch vizio model E701i-A3E and the picture went out. I still have sound and you can see a blueish backlight.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Troubleshoot Visio 60" E60li-A3E failure
Here is a guide to TV boards, use it to find out what they do and which one or ones may be faulty. TV Boards Buying Guide
My 70 vizio E701i-A3E lost picture graually over 30 seconds while audio remained unchanged.
Did the picture fade away or worked one second and the next it was black?
Replaced all 3 boards in ViZio E701i. Backlite comes on & set immediately shuts off.
I would claim the 180 day warranty on the parts you got. Chances are one of them are defective. It's rare that the display or backlighting shorts out and causes shut down of the system.
By the way, you put this in the Wall Mount category not TV's,
Fix a vizio E701i-A3E with no picture/video.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
1helpful
Have a vizio,; model E701i-A3E and it suddenly stop showing image, have sound and screen is lead and also have light on the back any help will be much appreciated . thank you.
Try a hard reset to this set, and check. If it do not help you, its T'Con board is faulty. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
