Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hello i have a hobart lx40 dishwasher is it a manual water fill or is it suppose to be hooked up to a water supply?
    Problem Solver:
  • 10 Answers
It needs to be hooked up to a water supply (hot line).
dont forget the drain.
good luck
Posted on Aug 21, 2009
    Scholar:
  • 109 Answers
The fill hose going to the fill valve under neath the wash tank, requires a 20 psi connection to 120-140F water. Each cycle will call for water 3 times. Wash, purge and rinse. LX's need their wash tank probes kept clean of scale and debris. Just wipe with your finger tips to crumble away buildup. Preventive descaling is recommended for hard water conditions.
Posted on Aug 08, 2009
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Water wont come in the dishwasher. It is heating with out water and then smells like plastic burning. Hobart LX30
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Apr 18, 2011 | Hobart Dishwashers
Wash Temp will not get above 140
It depends on the design & the programming. By chance if the thermostat is faulty this can happen. However refer user manual and consult the service provider or the manufacturer!
May 21, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Hobart lx40 Dishwasher stopped working
Look behind the dishwasher and you will see a cover on the right side,remove it.You may see a transformer with a fuse,check the fuse with a meter if you know how.Open the door look up to the right and left,you should see 2 phillip head screws,remove.Pull the top drawer with the display towards you.If you get this far let me know.
Apr 07, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
We have a Hobart dish washer in our bar area and when it sits over night there is a pool of water on the floor in the morning. When we open the door and look at the upper right corner in the rear of the...
The model is most likley a lx18,lx30,lx40.The fill solenoid valve is stuck open.Remove the 2 screws on the bottom front where the pressure gauge is.Turn the circuit breaker off.When you remove the cover you will see a bronze valve with a red hose going to the booster.Turn the water supply off.Remove the red hose--water will come out and is normal---remove 2 nuts that the valve braket attaches to the booster,remove the 2 wires on the valve and pull the whole assy. out towards you.Take the valve apart and clean see if it works,if not you need a repair kit.Part # 271838 or 290336 hobart numbers.I'm a hobart tech---let me know.
Feb 26, 2009 | Hobart Dishwashers
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart Dishwasher
Either the drain body is stuck or the solenoid is bad,give me a little more detail,model of the unit lx18,lx30,lx40,lxi?
Jul 04, 2008 | Dishwashers
Hobart fx25 dishwasher
I think you may have the wrong model number of the dishwasher.I work for hobart but i dont recall a dishwasher with the model number you givin me.Look on the data plate again some examples of hobart dishwashers are--sr24---am14---c44---c44a---lx18--lx30--lx40---lxi---uw50--sm6t2.Once you find the model goto this site and you will find a manual.any other questions let me know.http://www.hobartcorp.com/default.aspx
Nov 22, 2007 | Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
280 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
