Question about Maytag Atlantis MAV6000 Top Load Washer
Is this the bearing
This washer was working ok and recently has started to make a LOT of noise when spinning. Can you help me locate the problem? I had the front off and the tub spins a little off. There is a yellow material under the transmission. Is this a bearing?
  • mikeb1 Nov 22, 2007
    Thank you for your time and thoughts on this problem. I have looked into the tools and I think it would be best to have some help on this. I won't try this one on my own. Happy Thanksgiving.
  • 240 Answers
The yellow condition usually means the transmission has a leak or crack in it. This fluid could be causing the bearing to make noise or it could actually be the transmission doing it. Also, sometimes that yellowish stuff could be coming from the bearing getting water in it from a leak somewhere. Check everything really good for leaks. Understand though, unless you have two special tools, do not attempt to do this job yourself. You need a spring removal tool to remove the springs, and a special brake removal ool for the bottom brake. Be sure you dont remove that brake assembly without this tool, the plate will come off with a huge amount of force. Let me know if you need further help or information. Jim
Posted on Nov 19, 2007
  • James Greene
    James Greene Nov 22, 2007
    Probably the best advise I can give you. Those brakes can really hurt you if you are not careful. Good luck in which ever way you go, let me know if you need any further information, and Happy Holiday's. Jim
Back in 2010, our Maytag Neptune started making a lot of noise on high speed spin. I replaced the bearings and seal and all was good. Recently, the machine got noisy again. I just replaced the bearings and...
Usually four items are changed. The two bearings , the seal, and the shaft. When you did your first repair the shaft should have been replaced. The reason the noise continues is that the shaft wobble even as minor as it may be ends up beating the new bearings to where they start making noise again. The new kits are better designed and can be found for under 100.00 dollars. Shop around for the best price. Good Luck Friend.
Oct 17, 2017 | Maytag Neptune MAH5500B Front Load Washer
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Rear drum bearing
When it is like that you usually need to replace the drum bearing.
If the tub recently started making a lot of noise, and you can feel that the bearing had too much play when spinning by hand, that means that the drum bearing needed to be replaced.
You can find drawings and the schematics entering model number here.
Mar 07, 2009 | Hotpoint Dryers
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Washer noise
probably is the bearing will eventualy start leaking from seal
Mar 12, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Roaring washer
This is probably a part of the tank water seal. There is a bearing in there also. Does it leak water from that area? Usually the seal goes bad and it starts to drip water down into the bearing below, which starts to rust and then starts to make noise. If you can locate the bearing, you might try dripping a small amount of oil into it to see if it changes the sound any.
Nov 17, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
143 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
