PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
HP NX 6110 Laptop problem
By njekwa on Nov 19, 2007
my laptop continually freezes, wen i move it abit its starts processing, iv tried flashing the bios,repairing dry joints with no luck. basically am stuck
Comments:
Nov 19, 2007
- it freezes as in all processes halt, wen i move into another position its starts processing
Nov 19, 2007
- Not just the mouse, the whole system
Nov 20, 2007
- Basically, its like the is something not seating very well, i thoght it was the hard drive once, changed it the problem continued. what happens is this, when ever the laptop is placed on the table all any surface it freezes, even in my hands, for it to start processing, i negotiat angles... i have 2 Nx6110 notebooks with this problem
Same Problem
Mar 01, 2008
-   i have the same problem but in my case when it freezes i need to hold the power buton until it shuts off.
It hangs completly not just the mouse and it happens when i touch the touchpad mostly.
I thing something is going wrong with the chips undernith touchpad...
any help would be apriciated
thangs in advance-   sac1one
Solution #1
posted on Nov 19, 2007
Somewhat Helpful)
bluenadas
Rank: Guru
Rating: 86%, 269 votes
Can you give a little better description of the issue. When you say it's freezing do you mean the mouse locks and you can't do anything?
Comments:
Nov 19, 2007
- If you're running Windows, go to the Microsoft support site and search for Process Explorer. It's a program similar to Task Manager but has a little more to it. You'll want to download that and install it. Once you have it running you'll be able to see exactly what's hanging the system. Run the program and sort the items displayed via CPU usage.
You say when you move it, it begins to process again....you mean, after it locks you can pick it up and move to another location and everything begins to work again?
Can you pinpoint what actions cause the lockup?
Was this helpful?
Yes
No
Solution #2
posted on Dec 05, 2009
Not Rated)
emiliano72
Rank: Apprentice
Rating: 0%, 0 votes
IT'S A CHIPSET PROBLEM - faulty connection resolved (or better-patched) with pressure on it: see here and good luck ! http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1260029524885+28353475&threadId=1096080
Was this helpful?
Yes
No
Solution #3
posted on Mar 03, 2009
Not Rated)
igor106
Rank: Apprentice
Rating: 0%, 0 votes
I've fixed two laptops using this free tutorial http://imateski.blogspot.com/2009/03/fixing-non-responsive-hp-nx61106xxx.html.
Both of them still work, a year after the fix. No freezeups whatsoever. The fix requires quite a bit of explanations, so just follow the link.
Was this helpful?
Yes
No
Solution #4
posted on Dec 26, 2007
Not Rated)
jfinkle
Rank: Apprentice
Rating: 0%, 0 votes
I came into possession of a nx 6310 that my company disposed from inventory due to a display issue. The problem that is described here is very similar to the display issue this machine has. When the LCD screen is moved out of the 'sweet spot' it will lock up, or start to fail to display, the screen itself will go non responsive. If the monitor is moved just a little, it may go back to displaying properly. I believe that it may be a connection issue between the system board and the lcd but I am not sure. Any input would be greatly appreciated.
Was this helpful?
Yes
No
Solution #5
posted on Dec 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem, with the same laptop
Sometime it freez, stop working (no mouse, music which is playing stops), then if I press gently with one finger the plastic between keyboard and touchpad, it keeps going, not crashing any application at all. Not a software problem, since I have it on Windows, Ubuntu, and with a live CD too.
If it can help, lately the internal usb had stop working some weeks ago
any toughs?
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in... (More)
Answer
Laptop HP DV5000 when off, I plug ac and it turns on by itself without using power button. When... (More)
Answer
I have no sound from the speakers or the headphone jack. I ran the diagnostic program and got a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
