Question about Kenwood Excelon KVT815DVD Car DVD Player
Exessive engine noise - Kenwood Excelon KVT815DVD Car DVD Player
Try grounding the case to your unit .use a thin wire and take one of the screws out of the rear corners of the unit .Wrap it around the screw and tighten it then find a god ground inside your dash where the unit gets mounted (you can also put it in where the antenna plugs in ) that should do dit worked for me good luck
Posted on Aug 22, 2009
Nissan navara D40 making winding/whining noise when over 1500rpm
turbos normal make a whining noise under load noise may be present more then before if you have changed anything on the intake side sometimes it can be as little as a lest restricted air filter other cause is lose piping but some power loss would be noticeable if this was the cause
hope this helps good luck
Jan 15, 2014 | 2010 Nissan Navara 2.5
I have nokia 5130 hand set and i am using internet use gmail yahoo etc i can set email but i can not chatting exess. how to exess
for for some models it will be not available to access and another problem is according to network also it will be happened. another tip is to change the software of your cell
Sep 10, 2010 | Nokia 5130 Cellular Phone
06 charger, 5.7 Hemi 45,000 miles. Running great with no problems. Stopped to fill up with 93 octane gas. After filling up, I started the engine and it was running rough and making a knocking noise. I took...
were you running 93 octane before?try new spark plugs.engine that size shouldnt be worn out in 4 years..get it put on a tunescope,an ETOC one[ETOC every turn of the crank]it should tell you a few things.lots of money for a new engine,so check things out first.
Jul 11, 2010 | Dodge Charger Cars & Trucks
Victor lathe 1860 dcl
may be heavy load is drawing exess currant
Jun 21, 2010 | Victor 16" Swg 40" Cc 1640b Engine Lathe...
Noisy brush roll
To me this sounds like the roller could be worn, it may be time to replace, or have it replaced with a new one. Make sure that your machine is off and check by wrigiling it around, if there is exessive movement you have found your problem.I hope this helps.
Nov 04, 2009 | Vacuums
Exessive noise when in spin cycle?
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
Jun 23, 2009 | Maytag Dependable Clean Top Load Washer,...
Noise when engaging 4wd
I have had this problem and it could be one of three things, first the truck has automatic locking hubs, lack of lubrication to these hubs could cause them to make exessive noise while engaging. also you could need to lubricate your universal joins on your forward drive shaft. lastly my problem was abs wheel sensor actuator in drivers front hub had (internal part of hub looks like a large gear with teeth) had broken a gear off causing the hub to get wear in it making it clunk while engaging the four wheel drive.
Dec 20, 2008 | 2000 GMC Yukon
Volkswagen City (Mark 1)
this is quite normal for an older vehicle as long as when you say alot it doesnt mean having to top up the oil every week.
Jul 01, 2008 | 1994 Volkswagen Golf
Kenwood Excelon KVT815DVD Car DVD Player Logo
52 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
