Question about Coleman Powermate Powermate 5000W Generator
I have a Coleman powermate Maxa 5000 ER generator that was purchased several years ago but never used. Recently I used it and all worked great unitl I shut it down to refuel. When I restarted the generator it has no 120 V output. I "flashed: the unit but still can not get any power out. Any suggestions would be helpful along with a schematic. TY
  • faaet Jul 31, 2009
    Thanks Bobcatflusa. The generator had a bad diode so I replaced both diodes and the capacitor. Thanks for you help.
    Tony
  • 57 Answers
Http://www.powermate.com/productmanuals.php?cat_id=3
Try this link.
Posted on Jul 30, 2009
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
I have a coleman maxa 5000 PM525202; I bought it at a garage sale (didn't run); cleaned and rebuilt carb, changed oil, etc, and now it starts great and idles great. But ther eseems to be a part of the...
Parts lists for Coleman generators are here: http://www.jackssmallengines.com/coleman_parts_lookup.cfm
More detailed information about the engine can be found by using the engine model number. Look around the fan shroud or engine block. Coleman used different engnes, however your gen may have incorporated a Tecumseh 10 hp engine. Good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
I have an opportunity to purchase a used powermate maxa 5000 er and a used transfer switch that it was used with. it is a 6 circuit type box. i was suprised to see that the generator was old enough that it...
There is no reason not to use the plug... it may vibrate out though...that's what duct tape is for...:-)
The electrician should hook it up,, I would no problem...those tranfers are apiece o cake....
I say go fer it...
heatman101
Aug 29, 2010 | Coleman Powermate Powermate 5000W...
It is not a problem like to know if i can use my coleman 5000 maxa er plus 10 hp. With A welder with out damage it. Tanks
Yes, you can use a welder with it. Pay attention to the ratings of the welder, don't exceed running watts of the generator. It would also be a good idea to try and use a welder that is less than the running watts rating of the generator. Then you would have some extra capacity to deal with fuel quality, maintenance history, momentary undervoltage, altitude, etc.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
Powermate Maxa 5000 er will not run stably
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at buffalonymann@yahoo.com
Sep 24, 2009 | Coleman Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
4,350 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
