Question about Neff 24 in. S5443X2 Built-in Dishwasher
My NEFF S5443X1GB suddenly began leaking today. Water is now flooding from the bottom of the door but I don't know if this is associated with the seals being broken or the drain being clogged. Any thoughts?
5 Suggested Answers
  • 7 Answers
SOURCE: Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Posted on Oct 09, 2008
ginko
  • 19396 Answers
SOURCE: modell S5443X1GB water not pumping out,no
First you need to ensure that the drain pump is working.
The drain pump is tested by the technician by energizing the pump directly, so to understand if the pump solenoid is working.
This is an unsafe job for the home user, as there is AC inside your appliance, all live power test should be done by techs.
Apart testing the pump, check also the wiring harness to the pump.
If the pump is fine, then replace the control panel.
Here you find parts for your appliance and repair help.
Posted on Mar 04, 2009
  • 3247 Answers
SOURCE: NEFF S5943 slimline dishwasher leaks
It is very likely the door seal is leaking. Try again in the rinse cycle and see if you have the same problem. The water should not be warm this time but that will confirm if it is related to the duration of the wash cycle.
The details of the door seal are available at the NEFF parts website. You will have to select the assembly dwg 3 from the interactive screen to see is part no.
Hope this helps.
Posted on Aug 26, 2010
SOURCE: We have a neff dishwasher and the pump is draining
Hi there, our neff S54T09 doesn't seem to want to fill with water, it starts to fill for about 5 seconds then stops, then stops & starts filling for about 10 seconds then stops completely & nothing happens!! Have checked the water inlet & its filter & they are ok.
any idears Regards Peter
Posted on Apr 06, 2011
My Neff S5443X1GB/07 dishwasher stops after approx 20 mins of washing, the water is nice and hot but it needs the door opening and closing several times to encourage it to progress a bit further of th
If your unit has a round dial timer (like many washer machines) the timer may be sticking. If it has an electronic timer then the door switch may be faulty. Don't run this unit unless someone is nearby, if the door switch shorts out, you may have a fire.
Jan 02, 2015 | Neff Dishwashers
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
May 21, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Modell S5443X1GB water not pumping out,no
Mar 04, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Water inlet hose not letting water through to the machine
that's probably a flood-safe type hose ... most of them reset after you remove it and re-install where it connects to the faucet, but you have already swapped it . try removing it and reinstalling it , then turn water supply on slowly
Jan 16, 2009 | Neff W5340X0 Washer
Dishwasher NEFF S5443X1GB/17 .. chalky residue, where and how do i add salt ?
if you mean dishwasher probably you have hard water and residue is from buildup in unit ..try using a dishwasher cleaner like dishwashermagic ..after through cleaning try using white vinegar to keep build up down
Nov 18, 2008 | Neff Washing Machines
Dishwasher
Water in the bottom under the metal gride are absolutely normal. This water will be drained out at the beginning of the next cycle.
Sep 07, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff 24 in. S5443X2 Built-in Dishwasher Logo
53 people viewed this question
Top Neff Dishwashers Experts
shaun taylor
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
