Question about Nokia 6310i
Nokia 6310i Hello..I am getting no signal from my 6310i, a friend changed the antenna!!! and stil the same problem?Thanks.Brian.
  • chirpy Nov 20, 2007
    wtf didn't you let me know that you are only after my money, of which I have very little?
  • Anonymous Mar 07, 2008
  • 151 Answers
Have you tried bringing it to a technician to have it checked? It would be easier to have a professional replace the antenna rather than having to do it yourself... Good luck with your phone repair...
Posted on Dec 09, 2007
NOKIA 6310i is restricted, i need code
Yes You can get that easy,You can just Visit the website buy the Nokia 6310i restriction code at low cost.
Jan 27, 2011 | Nokia 6310i
Instructions for Nokia 6310i
how to change nokia 6310i alarm tone
Dec 29, 2010 | Nokia 6310i
How do I change incoming calls on Nokia 6310i from Silent to Normal. Thanks. I have scrolled through all the Menu on the phone, The incoming call shows General but testing incoming calls still shows as on...
sir go to the settings menu and go to the tone settings and increase the volume from one to the maximum level ...............or switchoff your mobile and on it problem gets resolved
Nov 17, 2010 | Nokia 6310i
Nokia 6310i
You mean your phone have a weak signal? There are many factors affecting the signal of your phone. It might be the phone service provider whose encountering a technical difficult on there system, there is something blocking your phone to receive strong signal like the trees,large building or maybe you are in a remote area where signal are difficult to reach.
But if you mean your phone is completely cannot receive any signal then it must be its hardware antenna inside that needs to be check or replace. You need some tools to do the repair like a soldering gun,screw driver and tester to do the diagnostics. If your unsure on how to do this then you need to visit Nokia Care Center about this.
Good Luck!
Don't forget to rate! Thanks..
Mar 30, 2010 | Nokia 6310i
Nokia 6310i - Low and No signal
It's possible that you could fix it, but not entirely likely. It depends on whether it's just a bent antenna connector or if a circuit board is broken.
Some phones have a small spring-type piece that makes contact with the antenna. If this is merely bent, and not making a great connection, you might be able to coax it back into shape and that might fix your phone. Otherwise, it's probably beyond the ability of an amateur to repair.
Nov 06, 2009 | Nokia 6310i
My phone is no network
Friend, if it has no network. check the following: battery be sure it has enough current to supply the unit. 2. be sure the SIM CARD is good and functional. 3. Check the Antenna if properly connected.this the metal plate at the back. 4. go to the setting then perform manual search.if appears signal the faulty is the antenna switch (hardware inside) or P.A. amplier (hardware inside) if no signal stil then the problem is audio IC. name COBBA that needs to be replace. Installing the hardware may needs expertice so ask the mobile technicians around you. good luck
Jun 16, 2009 | Nokia N72 Cellular Phone
Nokia 6310i
Brother, it seems it's generic network failure problem. Such problems are due to it's defective antina switcher, PA or any other part of network section. Which part is responsible that can be decide only by phisical examination. Any skilled technician can do it for you. He can set it right. Ask fixya for nearby skilled technician. If this post clears your doubt then do vote to FIXYA
Jan 08, 2008 | Nokia 6310i
Trying to access the appropriate network manually. Check Reception or Transmission is working properly.
Apr 29, 2007 | Nokia 6310i
Nokia 6310i
check the top left corner of the screen, is there a "2" there. If so you are set to use line 2. You need to change it back to line 1. select menu-settings-call settings-line for out going calls-select. Choose line 1.
Jan 26, 2007 | Nokia 6310i
Nokia 6310i Logo
138 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
