Question about Casio Exilim Cameras
Camera resets every time I turn it on. Have to input date, time, etc. Fully charge battery. It is shot?
SOURCE:
jackboy
  • 2985 Answers
SOURCE: Camera forgets the date. asks for dae setup every time I put on the camera
Will the camera work without this item set up or does it stall there? If it works otherwise, just live with it. There is not a 'repair option as such- you could check out the Polaroid Web site tech support team though
Posted on Jul 12, 2007
  • 374 Answers
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Posted on Mar 30, 2008
  • 5 Answers
SOURCE: Kodak Z700 not firing up
Guest is right. Clean the contacts, bend the contacts with a small flat head screw driver upwards "GENTLY". This should work. Might have to repeat every couple of months. Forget regular batteries. Use the rechargeable ones. MUST be fully recharged.
Posted on Sep 24, 2008
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
SOURCE: Kodak z1275 easy share camera
never use kodak again!!!
Posted on Dec 17, 2008
How to reset
Try resetting the camera by removing the battery for 15 mins. Then install the fully charged battery in the camera and go to the menu and set the Date and Time.
Mar 06, 2013 | Sony Cyber-shot DSC-S750 Digital Camera
Configuring display language, Date and Time Settings.
Perform the reset operation to initialize the camera’s setup (page 136). After that, configure each setting. If the language selection screen does not re-appear when you turn the camera on, it means that the camera’s built-in memory management area has been restored. If the same message appears after you turn power back on, contact your retailer or a CASIO service center.
Main support number800-962-2746
http://www.fixya.com/support/p504372-casio_exilim_ex_z1000_digital_camera/manual-19919
Jan 29, 2008 | Casio EXILIM EX-Z1000 Digital Camera
I have to reset the country date time etc every time i turn my camera on, i have tried going through menu and reset but this hasn't solved the problem. Please help
There is a built in battery that can keep the time date etc. info for 20 something hrs. without any other source of power. If your camera has a charged battery, is plugged into an active USB or powered by an adapter and you shut it off and then immediately turn it back on again, what happens? If the clock needs to be reset are you sure that you have completed setting the time. After adjusting all the settings you hit set. Most likely it seems that your internal battery is bad. It should charge when the camera is being powered by the main battery.When you say every time you turn it on I'm not sure what that means. If you turn the camera off and remove the battery for more then 30 hrs. it will have to be reset. If that is the case you need to leave a fully charged battery in long enough to charge the built in battery. If the built in battery is bad you will need to find out if it can be replaced.
Aug 04, 2010 | Casio Exilim EX-Z750 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
My DSC-W120 Sony camera won't turn on OR remain on. If I remove the memory card and the battery and reinsert them, the power might come on for 1/2 a second. The battery is fully charged.
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Sep 14, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 23, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Camera not staying on
Please use New rechargeable batteries now as old one has lost ability to store charge for longer time.
Nov 29, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Set date and time comes up every time i turn on camera
Feb 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The date time is controlled by another 'button' type battery in the camera- like a watch battery, there 'go' in time.
This is not a 'user' fixable item usually because it mean dismantliing the camera.
Sending away will be pricey- well on the way to the price of a new camera
So just live with it - I would
Nov 17, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak easyshare CX7430
My Kodak camere was really not dropped. I put in new batteries and the camera only gives me one shot and I have to turn it off and try again. I can plug the camera into a charge cord and I can take all the pictures I want. Is it possible the 2 batteries are not enough to power the camera
Mar 28, 2007 | Kodak EasyShare CX7430 Digital Camera
Cameras Logo
49 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
