Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer model# mav6451aww
I have 2 problems.
1- when the washer is workinig it makes noise; it made noise when we first got it but left it alone and works fine, what is causing that noise? Can i fix it? What part do i need?
2-Now when we wash the knob does not turn (timer) and the washer just turn forever so we turn it off because it get hot and smells like burn, can i fix the knob not turning? What part do i need?
  • 3 more comments
  • azar34 Nov 20, 2007
    I am having the same is making a roaring noise. The spin cycle works fine, no issues...but after it fills with water and starts the agitation makes a noise.
  • iamanewbie Nov 20, 2007
    when the washer turns it squeaks.
    When the washer was working it makes squeaking noise only when turning (washing) the washer spins no noise.
    when the washer was working it makes a squeaking noise when turning ( washing) spinning no noise its fine;what part do i need to repair the squeaking noise?
  • edziu Nov 27, 2007
    When the washer is in the agitation cycle is sounds like tumbling rocks under the machine, but it is fine during the spin cycle. The washer level side to side and front to back.
  • 240 Answers
Your first question I need a little more information. What kind of noise is it? Is it a squeek, or a roar, or like rocks in the tub? The second answer is more than likely a timer problem. This part (Maytag # 22004189) costs around $60 to $75 depending on where you live. Run that part number through eBay for special deals sometimes for those parts. Be sure you find out what that noise is first. If you have a transmission or bearing going bad, that could be a costly repair. Let me know what that noise sounds like, and we'll go from there. Jim
Posted on Nov 19, 2007
  • James Greene
    James Greene Nov 21, 2007
    Ok, thanks for the information. Do you know how o remove the front cover? If not, write me back. Sounds like a loose belt or motor pivot issue. The motors on these are susposed to move slightly while in agitation. They are on a sliding plate that moves forward and back depending on belt tension. If this plate is tight or bound-up it will squeek or cause the belt to squeek. You can actually get to this from underneith. FIRST, UNPLUG THE UNIT PLEASE. Lift the unit up and prop it against the wall. Put something strong under the unit to keep it from falling on you. You will see the motor pully in the corner. Grab it and try to slide it around a little bit. Spray some WD-40 or other type lube on the sliding system, plates, and bolts. Look for rust and clean everything off the system. Try that and see if it helps. If not, give me a write back, and we'll go from there.
Maytag washer, belt is slipping how do i tighten it and would this cause a black substance on floor
Posted on Jul 21, 2009
Maytag mav6451aww squeals loudly during spin cycle
The squeal you here is from the drain pump going out. I have replaced so many of these it's not funny. The new pumps are redesigned. All you need to do is remove the belt from the bottom, open the access panel on the rear left side (as you look at from the rear), remove the three bolts and pull the pump out. put the new one on in the reverse order. Here is the new pump.
Oct 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
How can i remove the cover to replace water
Goto Maytag - Historical Service Library
Put in your model number. I then go to would Sears Parts Direct with your model number and search for your replacement. I would then put that p/n in the price comparsion search engine. AZ is my choice. Good luck....Rich
Dec 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The washer emits a foul odor when washer first
You have the beginning of a detergent and/or softener residue buildup on the inside of the plastic outer drum of your clothes washing machine. Mold and bacteria need a moist, dark environment and a food source to grow. This residue is the food source. This can be a major health concern. See:
We can't change the environment of the washer but we can lessen the "food source" by reducing detergent and fabric softener use.
Do an internet search on "Smelly Washer Reviews" to see what you can do about the problem of mold odor in your washer, towels and clothing.
After your washer odor is gone you'll need to change washing habits so mold and bacteria don't return. Go to the blog page at to read the featured posts on the left side of the page on the cause of the problem and what to do for extreme cases of washer mold odor.
Dec 19, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis makes noise when in agitation
depending on what the noise sounds like,
it could be a couple of things
1. the belt is slipping
2. the aggitator is slipping
3 there is something in the pump
if you can take the front off,
two clips between top and front
then you should be able to see the pump
put your hand on it
sometimes when things get through the pumlp
it ruins the brearing and it sounds ike a screech
Oct 12, 2009 | Maytag Atlantis MAV6451 Top Load Washer
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mayatag Atlantis Top Loader Washer Model MAV6451AWW
there are two clips about 3 inches in from the corners in the front between the top and front push a putty knife into the space between the top and front panel about 3in in from corners and lift the front of the top.
May 12, 2008 | Washing Machines
Maytag Atlantis Mav8600aww
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Apr 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
1,135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
