Question about Canon PIXMA MP610 InkJet Printer
Paper misfeeds inside the printer
The printer is constantly misfeeding paper causing jams. I have cleaned the printer thoroughly and there is nothing inside to cause a blockage.
I followed the advice of one of the posters by removing the paper and putting through a sheet of photo paper through the copier. When I noticed that the blockage was a small pebble-ish object, I poked at it with a long knife and then the photo paper helped to push it through. That did the trick!
Posted on Jul 19, 2009
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
I have a paper jam and I can't locate the problem. I accidently loaded the printer with paper not knowing that several sheets had been stapled together. I removed the jammed paper but it still keeps...
  1. Turn the printer off and unplug the printer from the A/C outlet.
  2. Open the printer and check the paper path for a paper jam or misfeed.
  3. When the paper appears as crumpled or waded up, carefully remove all the jammed paper.
  4. When the paper appears to be angled incorrectly, it may be misfeeding through the printer, remove the sheet of paper.
    • Remove the paper stock and reinsert the paper, make sure the paper guides are adjusted correctly.
  5. Close the printer cover(s).
  6. Plug the printer into the A/C outlet.
  7. Turn the printer back on.
  8. Resend the print job.
  9. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Dell Printer Support
Feb 26, 2014 | Dell 3110cn Laser Printer
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
The paper is misfeeding to the right
clean the rubber roller carefully so it can guide the paper again properly canon ink cartridges
Dec 03, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Paper jam
I would like to inform you that this might cause due to dirty paper rollers hence Please click here and follow the instructions to resolve this isse.
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Paper jamming and misfeeding
misfeeds usauly mean worn pick up rollers. this can also cause the jammin of the paper as well if the paper is not folliwing the path correctly due to being picked from the tray at a different angle top nonmal. if you let me know the makeand/or model number of your printer i will try kfind the part numbers for you
Hope this helps
Pete
Nov 05, 2008 | Samsung CLP 300 Laser Printer
Paper jam
What that sounds like is misfeeding.
Remove your paper tray and take a soapy cleaner, like formula 109 or fantastic and thoroughly clean the rollers.
If that helps and it statrs misfeeding in a day or two, you probably have slick rollers.
Watch inside the paper feed. Make sure the paper is going against the rollers then see if they just spin on the paper.
Mar 27, 2008 | Canon imageCLASS D860 All-In-One Laser...
Paper misfeed
Try to clean the Paper Feed Sensor
Dec 15, 2007 | Epson Stylus Pro 4800 InkJet Printer
Canon PIXMA MP610 InkJet Printer Logo
111 people viewed this question
old marine
old marine
