SOURCE: I have the philips 120hz and some movies are smooth, others jump
I would advise knocking down the resolution. Try and use software, like red kawa, to convert a few of your movies to different formats till you find a decent one. A widely accepted codec setup is Divx/XVid (both are the same) and MP3 sound.
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
SOURCE: I have a 32 inch
Movies stored on a hard drive are not in a format that can be readily used by a TV. You need something to read the movie file, usually a laptop computer or a DVR of some type. Good luck.
SOURCE: I own a LG Plasma
The USB port on the TV might not have enough power to power the external hard drive. Can you try putting a movie on a USB memory stick instead, and see if that works?
SOURCE: how do i get my bravia kdl-52xbr6 to read usb flash drive?
Better hope it is not a actual problem as not cheap to fix--first thing to do is with set off--unplug for a while and plug back to see if a reboot will or will not help.
