Question about Troy Bilt Tb70ss Gas Trimmer
Fix the flexible drive shaft has a problem
Troy-Bilt 791-182833 flexible drive shaft has a little medal clamp at the end where the cutter is and it has come loose. Everytime I go to start up the machine it works for a second and then the cutter stops spinning. Then when tilt the cutter toward the sky it slips back into gear. So how far up the drive shaft should I put that little clamp and how do I tighten it correctly so the drive shaft does not slip out of place? Thanks
    Top Expert:
  • 2,931 Answers
The Metal Clamp referenced clamps directly on the end of the '2-Piece Gear Box Assembly'. The gear box assembly is an aluminum casting held together by 3 machine screws. The Metal Clamp does not actually lock the drive shaft housing into the gearbox assembly. The flexible drive shaft cable engages the engine output shaft, and the gear box assembly. This is a fixed length (non-adjustable) assembly.
First ensure that the drive shaft assembly is fully engaged at the quick connect fitting and that the "snap" is engaged. Then make sure the knob is fully tightened. The quick connect allows you to quickly switch between various attachments offered on this unit.
Now, based on your description, it sounds like the 'anti-rotation screw' 791-182519 has backed out or is gone. This will allow the entire cutting assembly (gearbox forward) to slip off of the drive shaft housing and disengage the flexible drive shaft. If your cutting assembly is attempting to rotate while in operation, or the drive is not engaged as you described.
Do not continue to operate the unit until you get this fixed as you could strip out the drive shaft end or cause other serious damage to the equipment or yourself.
If it is the anti-rotation screw, then make sure to push the drive shaft housing firmly into the gear box and ensure to align the holes in the drive shaft housing and the gear box. If the screw is lost, then find one similar sized, but be CERTAIN that it is not too long as it will actually engage the flexible drive shaft and prevent rotation, or cut the drive shaft.
Back to the clamp: If it is still wanting to move, then remove the lock nut and place slightly oversized washers on the bolt head and the lock nut. This will force more pressure (does not take much) on the clamp and will lock it down.
I just fixed mine today (071809) in fact and had to drill a new hole in the drive shaft housing as the original was completely wallowed out.
I hope this helps.
DROPNDEAL
Posted on Jul 19, 2009
Troy-Bilt Pony TB 465SS need to lock shaft to remove bolt extender to replace head with brush cutter head. Please help & Thank you.
Simple solution. Contact Troy-Bilt company. I am sure customer service would be more than willing to help.
Jun 02, 2015 | Troy-Bilt Garden
Troy bilt 25cc head won't spin?
I have run onto several of the Troy-Bilt with this trouble. Seams the part of the head where the flex drive shaft fits into is weak and gives up. Unfortunately this part of the shaft housing isn't serviceable and the shaft will have to be replaced.
Aug 25, 2014 | Troy Garden
Troy bilt troubleshooting
Bushing is worn out. You will need to replace the shaft. Fairly inexpensive.
Aug 24, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do you fix the trimmer shaft if it won't spin?
simple answer is no if you can do it yourself then yes
Aug 15, 2014 | Troy Bilt Tb70ss Gas Trimmer
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
String trimmer engine starts. head won't turn.
If your trimmer has been used for a long time you probably need to replace the centrifugal clutch. The high friction coeficient ferodo gets warn out and power dose not get transfered to the drive shaft.
Another problem could be the driveshaft itself. If yo overloaded the machine (for example by hiting a tree or rock) the driveshaft or a linckage could have broken
The only solution for this problem could be to disasemble the drive mecanism and see what is wrong.
Jun 29, 2011 | Troy Bilt 17Inch 31cc 2Cycle Gas Powered...
This is the second time in less than 1 1/2 years that the lower flexible drive shaft has broken. Any ideas?
My suggestion is to complain to Troy Bilt. The company is actively trying to increase it's market share and may be very willing to provide a new unit.
Sep 06, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you change the cutter blade on the TB Chipper?
I just did one!
There are two opposing threaded holes next to the shaft.
Screw in bolts and use a wheel or gear puller to remove.
You can use a socket that fits in the center bore for an extention of your gear puller.
auttozone or ayto supply rents for free w/deposit
May 22, 2010 | Troy-Bilt Chipper Shredder
How do you get the head off the troy bilt string cutter? I'm try
If by "tearing it up" you mean that little retaining ring inside the main body of the head, that's correct. It must be destroyed to remove the main body.
Very very few of these trimmers can use a different mowing head without suffering damage to the gearbox, driveshaft or centrifugal clutch. (These are VERY LIGHT DUTY trimmers.)
As for the advice you seek:
"Don't run any other head on this unit with expectations of the trimmer holding up."
Troy-Bilt offers other attachments for this engine to use in performing other types of jobs.
At my shop we see a huge percentage of these units with failed drive shafts and gearboxes.
Probably not what you wanted to hear, but it's better than telling you the wrong thing and then you end up being unsatisfied with the solution I offered. I truly wish you good luck.
Hope this helps,
Dolf-
Oct 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
1,585 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
