Question about Whirlpool LEQ9858P Electric Dryer
Dry does not start, door light on, timer ticking
I can hear the time when I set it and the light for the door is operational. The light turns off when the door is shut, must not be the door switch. Help?
  • Whirlpool Master
  • 1,606 Answers
You have a bad thermal fuse , located on the blower housing ( a slim white piece with 2 wires attached ) Pt # 3392519
Posted on Jul 19, 2009
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Dryer drum want turn
I am hoping the problem is the belt. One way to tell is to put your ear to the machine and start it, and see if you can hear the mortor whirring. You should. If so, the machine should be needing a new belt. Most belts last about 5 years. If there is no noise of the motor, you may have either a defective door swirtch ( they are cheap plastic) or you may have an electrical issue.
Be blessed.
Jun 15, 2013 | Kenmore Dryers
I have a Frigidaire LEQ2152ES Electric Dryer. The light comes on when you open the door. And the lights and sounds come on when you push the settings. Push the start button, and you hear the tick for...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have a whirlpool dryer, model number lgt6634dq0. The timmer does not stop after the drying cycle has ended. My guest it might be the timer. After the dryer has finished it's cycle I can hear the timer...
HI. The timer will be the culprit here. The timer motor is damaged, and the cogs seem to be worn, as well. I recommend replacing this failed timer mechanism. Once replaced, the unit will operate correctly.
Dec 03, 2009 | Whirlpool Dryers
I have a kitchen aid electric dryer Model KEYE660WWHO, serial #1422813. My dryer won't start. The fuses have been checked and are fine. When you select the drying time, you can hear it ticking, but when...
ma be the door switch push on the door switch with a screw driver to see if it comes on if it does you have found the problem. If that does not work let me know and I will help you solve the problem.
Nov 28, 2009 | Office Equipment & Supplies
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LEQ9858P Electric Dryer Logo
107 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
