Question about RCA Scenium D40W20 40" Rear Projection HDTV
Tv just cuts off and the power button blinks 5 times and stops
Blinks 5 more times over again. i unplug tv for a while plug back in sometimes tv comes back on.
  • 668 Answers
According to the service manual the lamp needs to be replaced.
Hope this helps,
Skyassoc
Posted on Jul 18, 2009
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My RCA 52W23 52-inch HDTV will not turn on anymore. I can hold the power button down and the green light will blink once, but nothing. If I press it again, it blinks several times, but nothing. Before...
The deflection board will ned to be replaced. You can get replacement deflection boards from www.tvrepairworld.com they will help assist that you get the correct board for your model.
Jun 25, 2010 | RCA D52W23 52" HDTV CRT TV
The tv will come on for a split second then click and cut off its a mitsubusi projection ws-55809
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
SD TECH
May 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red power lights blinks and tv will cut off. sometimes after you unplug it it will come on after about 10 min. now it will not come on unless you unplug it and then it will work about 5 min and cut off...
depending on the age of your tv, this appears to be a common issue. Blame it on the ballast board. your ballast might not be able to provide the lamp w/ enough voltage to keep the image on for longer period of times. or it could simply be that you need a new tv lamp.
Apr 13, 2010 | Toshiba 55HX70 55" Rear Projection...
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
NO PICTURE
it is you senser that when you take the back end of your cover off there is a little chip there just tape it lol
Apr 18, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
316 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
